More extensions isn't a problem, that is why i said i want to use a diagonal, also i have tube extensions, and i do have ADC if that is an alternative to interference eliminator, but i really didn't know that imaging the sun needs all that much of back focus, i used A wedge and K-Line filter and it didn't take all that much of long back focus, not sure about the Quark, i will give it a try one day.
2022 03 24 - Experimental barlow setup!
- Has thanked: 612 times
- Been thanked: 404 times
Re: 2022 03 24 - Experimental barlow setup!
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Tareq,
I have a Quark Chromosphere with internal 4.2x barlow.
I don't have a Quark Combo, but I am unsure if I can use a low Focal ratio refractor.
I was wondering if I can beat a Celestron C14 by using a 5x barlow with a 120mm ED refractor at F9, so I have a focal length approx 5000 mm, much better than a Celestron C14, saving me 11000 USDollars in the process !!
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Magnus,Boso36 wrote: ↑Wed Mar 30, 2022 11:51 am Hi Tareq,
Magnus
It is very funny that Daystar is making Quark combo for no use, i don't think all people buying it will use either SCT or Mak, i do have the Mak with F/15, and i have PM 2x so i can crank that up to F/30, but if i can do that with reflector i can do that with refractors, so i can buy something like F8-F11 refr and place PM 2x or even PM 5x and i am there already, so why that won't work compared to the Quark with Barlow 4.2x, i feel people don't know if they don't test and then assume the worse, i bought this combo so i can use Barlow or focal extender myself.
Tareq
- Has thanked: 18090 times
- Been thanked: 8934 times
Correct me if I am wrong but I understand that rear mounted etalons must have a parallel beam free of curvature entering the system. With f30 for Solarspectrum, is it f32 for a Quark? in order for the etalon to work at it's specified FWHM.
Therefore, this is why a Quark comes with a 4.2 telecentric before the Quark to achieve this. A telecentric is needed as powermates and barlows cause curvature of the light beam.
If you were to use a powermate or barlow it would have to come before the Quark not after it to achieve the correct f number entering it.
In cases like my C11 which is already at f10, I would get f42 if I used the standard Quark which would be too much. So they sell the Quark combo so I could choose to add a TZ3 before the Quark and get f30 instead.
I've lost the plot in this thread so I hope I haven't said what has already been said
