I have a question concerning my equipment that someone might be able to answer. I have a 10-year-old Lunt LS-80THAPT-B18F with the DSII internal double stack module. I was viewing the sun yesterday from my New Mexico observatory and I noticed that the pressure tuning knobs for both the telescope and the DSII unit seemed to be turning easier or more freely than I remember. I thought there used to be more resistance especially toward the end of tightening. I also noticed little change in the images when I loosened and tightened the knobs - at least not as much change as I remember. Is it possible that I don't have as good a seal as originally and the pressure tuning knobs are leaking? Is there something I can do to fix this (if it is a problem) - like adding some sort of grease on the tuning knob threads? I have not done much maintenance on this scope but it has always performed well for me. If anyone has any suggestions, I would appreciate hearing them. Thanks.
-Robert
Pressure Tuning Leaks on a Lunt
- rray6
- Has thanked: 2 times
- Been thanked: 15 times
Robert Ray
Last night as I lay in bed looking up at the stars in the sky, I thought to myself -- "Where the heck is the ceiling???"
www.redshift48.com
Lunt LS80 DSII B1800 f/7
WO 132mm f/7
Celestron 9.5 Edge HD f/10
Stellarvue 80mm f/7 Raptor SVR80ST2
WO Z73ii f/5.9 APO
Lunt CaK B1800 Filter and Baader Herschel Wedge (Photo)
PGR Grasshopper 3.0 (ICX687 - mono)
Player One Apollo M-Max IMX432
ZWO ASI178MM and ZWO ASI174MM with filter wheel
SBIG STT8300M
ZWO ASI2600MC-P
Canon 5D Mark IV and Canon Rebel T7i
AP 1200GTO (Permanent) and iOptron CEM60EC and CEM25EC Mounts
www.redshift48.com
WO 132mm f/7
WO Z73ii f/5.9 APO
SBIG STT8300M
ZWO ASI2600MC-P
- Been thanked: 10247 times
Re: Pressure Tuning Leaks on a Lunt
I fished out my LS50 the other day and found the same. I haven't tried it, but also figured greasing the threads would help. I haven't done it yet, and not sure what sort of grease it is. I know you can buy the grease from Lunt.
- JochenM
- Been thanked: 1619 times
Hi Robert
As Mark already pointed out, adding some grease to the threads is probably a good place to start. When I bought my LS50 a few years back, its threads were basically bone-dry and I added some simple silicone grease you can find in any DYI store; never had any issues with it. Additionally, inside the tuner knob there's an o-ring to keep things sealed. If that one has seen better days (you know how rubber seals get over time), it might be worth replacing it (Lunt sells them for a few €/$).
- rray6
Thanks Mark and Jochen for the suggestions. New Mexico climate can be harsh on things like grease and o-rings. I sent an email to Lunt yesterday detailing the issue. Hopefully, they will get back to me soon with some direction. I had been planning to put some silicone grease on the threads but will wait and see what Lunt says first.
-Robert
-Robert
Robert Ray
www.redshift48.com
WO 132mm f/7
WO Z73ii f/5.9 APO
SBIG STT8300M
ZWO ASI2600MC-P
www.redshift48.com
WO 132mm f/7
WO Z73ii f/5.9 APO
SBIG STT8300M
ZWO ASI2600MC-P
- Has thanked: 103 times
- Been thanked: 207 times
I’d also suspect the o-ring if the piston’s getting easier to turn and the grease doesn’t improve things. Lunt used to send out replacements for free.
Solarscope SF70DS + TV85
TSA-120, Baader wedge
- hopskipson
- Has thanked: 408 times
- Been thanked: 191 times
I had a similar problem with my LS80 that I got used on Astromart. It’s 11 years old and the o-rings got soft. After replacing them I still had a leak on the DS unit. I sent it back to Lunt and the collimating lens was chipped and leaking. They replaced it for $40. Now it works with no problem.
