On Saturday I had the first session of the new season, and the best seeing so far for the RC8/Lunt 50 setup. I can now reliably say that there are no more thermal issues - I imagine they would have an impact in the first few minutes of pointing the telescope at the Sun, but instead I got 45 minutes of good-quality material. I was also using my newer laptop and the new external 2 TB SSD which can sustain writes at several hundred MB/s indefinitely. I took 10-second videos at 226-280 fps (using my new Blackfly S/IMX273) and stacked 15% in AS!3 (post-processing in ImPPG). In total, I ended up with some 1.2 TB of data.
AR 2976:
AR 2976 animation (20-second intervals, 0:44 h total):
Small flash in CaK (achromat 90/660 mm, Lunt CaK B600, PowerMate 2.5x, 15-second intervals, 1:01 h total):
AR 2976 (90 mm/Lunt 50 setup):
Today the seeing was worse, but I pointed the RC8 at the new emerging sunspot anyway and caught some limb activity (20-second intervals, 0:35 h total):
Much improved Hα results from RC8
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
- Has thanked: 8352 times
- Been thanked: 8103 times
Re: Much improved Hα results from RC8
Nice results there. It’s such a challenge with these larger scopes.
- marios i.
- Has thanked: 1709 times
- Been thanked: 1125 times
Very good!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 6161 times
- Been thanked: 7096 times
- Has thanked: 17521 times
- Been thanked: 8763 times
Wow!! fabulous work Filip how did you solve the thermal issues?
