First good clean sky after a few days of rain.
Lunt LS40, B1200, 15mm Plossl, iPhone held up to the eyepiece. Crop, flip, rotate, shadows and hilights adjusted in Affinity.
The stripes (\) seem to be from the camera sensor. I haven't modified the colours - the surface detail is bleeding through on the green and blue channels. Makes an interesting colour scheme.
Certainly the view through the eyepiece is better (addictive).
Lunt LS40 and iPhone
- EricF
- Has thanked: 1238 times
- Been thanked: 270 times
- Been thanked: 4882 times
Re: Lunt LS40 and iPhone
Eric:
An interesting result with an IPhone, the proms look nice.
- Has thanked: 17458 times
- Been thanked: 16553 times
Eric F,
I have used the iPhone a fair amount for solar imaging as well. It can do surprisingly well, as you certainly have demonstrated here. I like seeing people try something different like this. Most people here use monochrome video cameras for imaging the Sun for good reason, they are the best, but that being said, good results can be obtained with effort and patience using a smartphone camera, point and shoot digicam, mirrorless camera or a DSLR. Use what you have to most effect. And with me the iPhone is always at hand!!
And then there are those like Marios. He sketches better than some people can image!!
- Has thanked: 20240 times
- Been thanked: 10111 times
That new scope looks to be a good one Eric! Nice capture with the phone!
- Has thanked: 17521 times
- Been thanked: 8763 times
- Has thanked: 9243 times
- Been thanked: 5502 times
Hi Eric,Makes an interesting colour scheme.
Well, about the colour you more or less hit the real colour of H-alpha.
Eric Roel, a member of this forum too, did photograph many many years ago a H-alpha light generator and look at the outcome. I do not know what sort of camera he used.
- Been thanked: 4300 times
Nice shot wit the iPhone Eric...well done !
- EricF
Thanks folks. The scope is definitely what I hoped for.
The iPhone is very handy. If there was an app called iRegistax, that would be even more fun!
That special colour from a hydrogen tube - I guess a mix of h-alpha and h-beta? Whatever it is, that's what I remember from the eclipse in 2017. Love that colour.
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
NIce result, indeed! Could you post the image without adjusting shadows and highlights? Just to see how it looks like looking at the eyepiece...
Best, Daniele
Best, Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- EricF
Daniele,
Here's a resized version - straight from the phone, no processing, but reduced in dimension to save space. You can see glare from where I didn't completely cover the iPhone. This is with an 18mm Radian eyepiece.
And here's a crop of the original to the same dimensions as the final image (no resize). Just a crop, no processing.
The view through the eyepiece with an eyeball is very similar to the GONG images... but very red!
