D-ERF right direction
these are all of the great references that our users have shared with others.
Moderator: marktownley
Geremia Forino
Has thanked: 50 times
Been thanked: 54 times
Post by Geremia Forino »
Hello Solar firnds,
just received my Baader D-ERF from ventors and I am a bit confused on the direction to adopt in the cell, if I remember correctly, the "V" engraved on the Corrector of an SCT indicated the direction towards the primary, in this case what should the direction be, Sun Or telescope?
D-ERF direction.jpg (2.48 MiB) Viewed 2327 times
Has thanked: 20757 times
Been thanked: 10444 times
Re: D-ERF right direction
Hi Geremia,
See my review of the Baader DERF - the arrow points towards the sun.
https://brierleyhillsolar.blogspot.com/ ... eview.html
LTHB
Been thanked: 581 times
Post by LTHB »
On their webpage Baader says (unfortunately in German only) that the "V" is meant to be an arrow, and the arrow must point in the direction of the sun.
https://www.baader-planetarium.com/de/d ... filter.pdf
Frank
Geremia Forino
Mark during a google search I saw this blog, I did not know it was yours, congratulations for the description.
as you can see you have a arrow, I have a "V" the confusion remained as I was referring to the optics of a SCT.
Thanks Frank to confirm the direction it points towards the Sun.
Simon2940
Has thanked: 1075 times
Been thanked: 1986 times
Post by Simon2940 »
If ever in doubt, if you hold something like a screwdriver or pen over the filter, if you see an infinity reflection of the item, that is what faces the sun.
If you only see 2 or 3 faded reflections (or even just 1 reflection), that side faces the scope.
Geremia Forino
If Simon has not been wrong, I am right, the "V" must point the telescope, just like in the SCT corrector.....I'm confused :?
Single Reflection
Single Reflection
single reflection.jpg (2.66 MiB) Viewed 2284 times
Multiple Reflection
Multiple Reflection
multiple reflection.jpg (2.65 MiB) Viewed 2284 times
Simon2940
Post by Simon2940 »
Ive always understood it as the multiple reflections should not be pointed at the sensor, otherwise when imaging, these reflections will be seen.
One side is a multilayer coating and the other is anti reflective.
I know this image is extremely confusing but hey, i could be wrong.
To be sure, go by what the instructions say. According to the PDF, the arrow points towards the sun.
Geremia Forino wrote: Tue Mar 29, 2022 10:15 pm If Simon has not been wrong, I am right, the "V" must point the telescope, just like in the SCT corrector.....I'm confused :?
Simon2940
Post by Simon2940 »
I just triple checked with an ERF that's already mounted, the arrow pointing TOWARDS the sun meaning that the multi reflection faces the scope (or camera). Im assuming a D-ERF is treated as narrowband filter which makes sense since its only allowing 600-700nm.
I was wrong. The mentioned is true for LRGB.
Geremia Forino
Thank you for checking Simon, this reassures me
