Do you know the Lunt 160mm etalon filter?
- mami813
- Has thanked: 151 times
- Been thanked: 236 times
Hello everyone.
There is a 160mm filter made to order in Korea.
I made an observation today. It was the best..
Do you know the history of this filter?
Unfortunately, a 160mm filter was used in the 150mm telescope. It's unfortunate.
Please understand that my English is not fluent.
thank you.
thank you.
- Bob Yoesle
- Has thanked: 543 times
- Been thanked: 812 times
Re: Do you know the Lunt 160mm etalon filter?
This filter is mentioned here, and I was told only a few were made. I believe they sold for around $14,000 - $16,000, and thus probably were not commercially viable - therefore the same fate as the Coronado SM140. The one shown indicates it was the fourth one made in the year 2010.
- Has thanked: 3107 times
- Been thanked: 2206 times
must be amazing for visual observation.. but only if you have often good seeing.
for imaging on the other hand i dont see much advantage over the cheap solutions with rear mounted etalons.
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 1640 times
- Been thanked: 878 times
Any thoughts on why they didn’t continue development of the pressure tuned front etalon (mentioned in the link)Bob Yoesle wrote: ↑Sat Apr 02, 2022 7:47 pm This filter is mentioned here, and I was told only a few were made. I believe they sold for around $14,000 - $16,000, and thus probably were not commercially viable - therefore the same fate as the Coronado SM140. The one shown indicates it was the fourth one made in the year 2010.
- mami813
hello dennis
Thank you for answer.
I hope the transaction with you goes well.
Jongho
- mami813
hi BobBob Yoesle wrote: ↑Sat Apr 02, 2022 7:47 pm This filter is mentioned here, and I was told only a few were made. I believe they sold for around $14,000 - $16,000, and thus probably were not commercially viable - therefore the same fate as the Coronado SM140. The one shown indicates it was the fourth one made in the year 2010.
Thanks for sharing some of the information you know.
- Been thanked: 2725 times
Waow, this is a big one ! Thanks for the photo.
If was wondering what is the size of the main telescope on which the TOA 150 is attached to ?
Bob, what about going triple-stack with this 160 mm etalon ;-)
- Has thanked: 20962 times
- Been thanked: 10593 times
Nice! Interesting to know and thanks for sharing!
- Bob Yoesle
No definite ideas - although it would take a clear window and the ERF for sealing the etalon - which would add weight to an already heavy etalon/ERF. Then it would need to be vacuum-tuned with a precision pump. For the 160, the usual piston might not have enough volume for the job.Any thoughts on why they didn’t continue development of the pressure tuned front etalon (mentioned in the link)
Wowzer!!! - if I found one I might consider it !-0Bob, what about going triple-stack with this 160 mm etalon ;-)
- mami813
triple stack? Just thinking about it makes me excited!!Bob Yoesle wrote: ↑Sun Apr 03, 2022 8:54 pmNo definite ideas - although it would take a clear window and the ERF for sealing the etalon - which would add weight to an already heavy etalon/ERF. Then it would need to be vacuum-tuned with a precision pump. For the 160, the usual piston might not have enough volume for the job.Any thoughts on why they didn’t continue development of the pressure tuned front etalon (mentioned in the link)
But there was no erf in front of 160mm.
There was a small erf filter on the back blocking filter.
- Has thanked: 17960 times
- Been thanked: 17110 times
WoW, what an etalon!! Though a bit smaller than the etalon the TOA150 is a top notch scope and should perform excellently with it. That's a big scope the TOA150 is mounted on!!
Hello Mami,
Could you have a picture taken from the front of the etalon to see whether there is any central spacer ?
Any image of the blocking filter ? Is is a "classic" one ?
- Bob Yoesle
I personally would NEVER mount an etalon - let alone the monster ones - on the dew shield of any telescope. You want to mount it directly to the objective lens cell proper if at all possible.
I would think the LS160 etalon would be best served by the "root 3" spacer system - and a single central spacer would have violated the Coronado Patent that Meade inherited from David and Andy Lunt et.al.
- Has thanked: 9830 times
- Been thanked: 5828 times
Hi Bob,I personally would NEVER mount an etalon - let alone the monster ones - on the dew shield of any telescope
You are correct. I have a TOA 130 and I have to say the play of this dew shield in the lowest position is quite play free and it looks as they have the dew shield in its shortest position. Just tested it on my TOA 130.
- mami813
hi BobBob Yoesle wrote: ↑Mon Apr 04, 2022 6:56 pm I personally would NEVER mount an etalon - let alone the monster ones - on the dew shield of any telescope. You want to mount it directly to the objective lens cell proper if at all possible.
you're right.
The etalon is made of three central spacers.
I also told the owner that it is best to mount it on the lens cell if possible.
Why should it be mounted on a lens cell?
thank you.
- Has thanked: 65 times
- Been thanked: 4462 times
Mami...
The dew shield is too flexible to support an etalon like this without sagging and ruining the ability to keep the etalon optics aligned properly.
I have the Lunt 75mm etalon, and it is too heavy to mount on the on the dew shield of my 80mm pressure tuned.
Still, it is an impressive sight!
- mami813
hi christian viladrichchristian viladrich wrote: ↑Mon Apr 04, 2022 3:05 pm Hello Mami,
Sooner or later, it will be shipped to me to manufacture the objective lens cell adapter.
Then I'll upload detailed equipment pictures again.
Jongho
Thanks Jongho, keep us updated with plenty of pictures.
