Calcium sun Saturday April 2, 2022
- Has thanked: 9074 times
- Been thanked: 5977 times
Hello all: this morning a mix of clouds and clear sky with below average seeing. This is a view of the sun using the Evostar 150ED stopped down to 65mm and the Quark CaH. Camera was the FLIR 174 chip that was literally flying at the 163 FPS nominal speed. At the beginning of the session I tried using the 2.7x Airylab telecentric but with the poor seeing I have to see if anything came out of it. It was fun, though !
You can see AR2975 and 76 flaring.
I dedicate this to our friend Terry, hoping he gets better soon.
- 095904 Multiple Ar's.jpg (199.71 KiB) Viewed 964 times
- SDO 040222.jpg (150.38 KiB) Viewed 964 times
- Multiple Ar's.jpg (196.63 KiB) Viewed 964 times
- FLIR 174 speed.jpg (95.92 KiB) Viewed 964 times
- Been thanked: 4300 times
Re: Calcium sun Saturday April 2, 2022
Great images Franco...well done
- rigel123
- Has thanked: 8189 times
- Been thanked: 8424 times
Wonderful CaH images Franco, your shots are at the same time as the end of my animation and I love seeing the flares from your wide angle view in a different wavelength.
- Has thanked: 17458 times
- Been thanked: 16554 times
Excellent capture Franco! I was observing this flare visually in Ha at that time with my SMII60. I didn't notice the bit of flare near the large spot of AR12976 but the ones in 75 I saw easily. The higher magnification and resolution of the SMII90 would have probably made all the difference here.
I'll post an AIA1600 closeup of the flare shortly in my report which gives a similar view to CaH and CaK.
- Has thanked: 8355 times
- Been thanked: 8103 times
Excellent images, Franco.
- Has thanked: 20240 times
- Been thanked: 10111 times
That's a nice CaH image Franco! You should use your big chipped PGR with the 65/1220 setup. You will tease out a lot more resolution with the smaller pixels of the ICX814 camera.
Thank you Brian, Warren, James, Stu and Mark. I will look through the close ups to see if any image is good enough to post, showing the flaring in more detail.
Good luck on that Franco.
- Been thanked: 4883 times
Thank you Eric. Of the 11 SER files I have of this region, this is the only one I could save that is not completely horrible because of the poor seeing and still shows the flaring.
- 095132 AR2975-76 close up - flare color.jpg (118.86 KiB) Viewed 901 times
- 095132 AR2975-76 close up - flare.jpg (115.44 KiB) Viewed 901 times
That's an excellent CaH view of yesterday morning's M-class flare.
Two thumbs up!!
Two thumbs up!!
Franco...the CaH flare images are excellent
- Has thanked: 660 times
- Been thanked: 619 times
Brilliant catching the flares! It may be my eyes but the monochrome seems slightly more restful & distinct than the coloured version - lovely.
- Has thanked: 6161 times
- Been thanked: 7096 times
Really nice CaH images, Franco! Very cool to see the flaring in this wavelength!
Arne
Arne
Thank you James, Brian, vineyard and Arne, greatly appreciated.
Very nice CaK work Franco. Well deserved.
JP
- Been thanked: 2703 times
Nice capture Franco !
