High camera temperatures
- Has thanked: 2978 times
- Been thanked: 2082 times
Hello,
what kind of camera temperatures do you get during imaging with larger apertures?
My setup atm is a 150mm f/8 ac, a 160mm d-erf + Baader t2 BBHS mirror diagonal and Quark Chromosphere. With this setup im getting relatively high temperatures on my zwo asi 174mm (noncooled), namely up to 53°C. So the camera sometimes just looses connection with the imaging software.
I have the sensation that something is off with my setup.
Any ideas?
Could it be that the D-erf is mounted in the wrong direction (Arrow is pointing towards the sun)? Or the arrow is wrong?
image quality is not much affected, though lower temperatures are always welcome because of noise.
Thanks in advance.
Any ideas?
Thanks in advance.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Geremia Forino
- Has thanked: 39 times
- Been thanked: 45 times
Re: High camera temperatures
Hi Geremia,Geremia Forino wrote: ↑Thu Apr 14, 2022 5:13 pm Hi Dennis, see if this can help you remove the doubt about D-ERF
viewtopic.php?f=7&t=35410
thank you, yes i checked this thread already. According to this it should be in the right direction, also congruent with the arrow marking.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
i forgot to tell the ambient air temperatures, they were around 17°C today, but the camera temperature went relatively quick back to 53°C after a short manual break (camera disconnected from the usb 3 port)
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Been thanked: 2713 times
Hello Dennis,
If you put your hand at the exit of the Quark, you will feel no heat. However, the Quark is thermo-regulated. It don't know what is the target temperature for your Quark. This might explain (or not) why your camera is warm.
Have you tested taking the camera away from the telescope and checked its temperature ?
Hello Christian,
that is a good tip. The Quark was warm as well when i disassembled all. The led was green all the time, so i guess it was working normal, also pictures seemed to be not affected. So i have to think of a cooling solution for the camera since i dont want to use plastic adapters for to adapt it to the Quark.
Thank you
Thank you
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Geremia Forino
yes, i connected it now inside the house to the pc, away from the quark, and it reaches up to 45°C. Something is weird there, i will continue to trace it.christian viladrich wrote: ↑Thu Apr 14, 2022 5:54 pm Have you tested taking the camera away from the telescope and checked its temperature ?
Thanks for the input.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 9412 times
- Been thanked: 5574 times
Hi Dennis,
What is the QUARK temperature ?
i dont have equipment to measure it, but doesnt feel "hot", just warm, maybe 35-40°C.
But i think its just the camera itself that gets too warm with this application.
Im looking now for a peltier cooling solution, or a used cooled version of the camera.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Strange. 45°C is rather high for indoor operation. I think Paul/Banjo has an ASI74. I can ask what is its operating temperature.Dennis wrote: ↑Thu Apr 14, 2022 6:51 pmyes, i connected it now inside the house to the pc, away from the quark, and it reaches up to 45°C. Something is weird there, i will continue to trace it.christian viladrich wrote: ↑Thu Apr 14, 2022 5:54 pm Have you tested taking the camera away from the telescope and checked its temperature ?
Hi Dennis,
As you can see you have there also already a delta temperature against ambient of about 18-23°C and this heat is on the outside of the QUARK as well as it will be on the thread or the nosepiece adapter.... but doesnt feel "hot", just warm, maybe 35-40°C.
You have to take into account that the QUARK is attached to the camera via metallic conection. So the temperature of the QUARK also helps to increase the camera temperature.
Connect the camera and do not activate taking images and wait maybe an hour and measure the temperature of the camera by switching it on and read the temperature the software is telling you. In this way you can see how much does the QUARK heat up you camera and from there you can calculate the temperature delta when the camera is active.
Just an idea ...
There are Multimeters on the market with temperature probes which you could tape onto the surface of the QUARK ¿?
i think the camera-chip-temperatures should be fine with 53°C on a warmer day with 20°C ambient air temp.
In the end i think it was a problem with firecapture being interrupted by workmeetings and other workstuff on the computer.. appearently it has some stability problems there.
So far recording seem to work when i dont have other stuff running in the background.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
BTW, you can easily install a passive heatsink on the camera. It will reduce the temperature of the camera body by 5 to 10°C.
Better than nothing ...
wow.. didnt know it has that effect. Thanks for the tipp. I was wondering how the chip can be efficiently cooled when there is no direct contact of the metal-housing with the chip. But seems to work then. I think i will have to do that at least in summer when its even warmer outside.christian viladrich wrote: ↑Thu Apr 21, 2022 7:05 pm BTW, you can easily install a passive heatsink on the camera. It will reduce the temperature of the camera body by 5 to 10°C.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Here is an example :
http://astrosurf.com/viladrich/astro/in ... r-B640.jpg
It is quite effective. Indeed, the body of the camera acts as a thermal dissipator for the chip.
Hi,christian viladrich wrote: ↑Fri Apr 22, 2022 7:50 am Here is an example :
And looking at the Body of the ASI 174MM it is even quite easy to adapt one on it as it has already a nice threaded hole for a 1/4"-20 screw = standard photographic tripod screw.
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
Bob Yoesle wrote: ↑Sat Apr 23, 2022 12:54 pm You might find this post of interest:
https://www.cloudynights.com/topic/3266 ... chameleon/
That is a very nice mod, thanks for sharing Bob.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
hello,
I made this assembly which allows to gain 4 to 5°, the most effective would be to insert a Peltier module to gain a few degrees.
The ASI 174 rises very high in temperature even when not connected to an assembly, this is the big problem.
Paul
Paul
