How ca be usefull this new ERF filter in a Quark Crhomo + TSA120 and FS60CB setup, both for visual and Imaging?
i have a ASI 178Mm and a Player One Max.
Usually in visual i use ia baader Prism t2 32 with a 2" astronomik UV cut on it.
Player One ERF
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: Player One ERF
It will prolong the life of the blocking filter in a quark for longer. For best effect it should be mounted higher in the optical path, Player One should offer a 1.25" extension tube that could go wit it. That would be worthwhile and not too much £££ more.
