Live floating sunspots! Penumbra ballet in 83 min animation of AR12293-4 in WL! 20 April 2022
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi all,
It's been a long time that I wished make this animation!
The seeing was medium good in the begging, but deteriorated rapidly. Nevertheless, with such beautiful ARs and sunspots I wanted to try a long animation in WL to see the sunspot penumbras moving and floating.
The seeing stopped me at 83 min (I discarded the last 7 captures), but I am still very glad that live and moving sunspots are visible!
The animation is at the end of the post... Do not stop at the photos. ;-)
First I made a H-alpha of the area. I was tempted to make an animation on this, but at the end I said I should try the WL, although I did not have the very good seeing I needed.
2022-04-20, AR12293-4-5, Lunt130MT, ASI290, 1.6x Barlow, 13_50_36 by H- Alpha, on Flickr
Then the same area in the Blue wing of H-alpha
2022-04-20, AR12293-4-5, Blue wing of H-alpha, Lunt130MT, ASI290, 1.6x Barlow, 13_54_48 UTC by H- Alpha, on Flickr
Then the first capture in WL, while the seeing was acceptable
2022-04-20, AR12293-4, Lunt130MT, ASI290, 2x Barlow, 14_14_48 UTC by H- Alpha, on Flickr
And finally...
The long animation in WL with the ballet of penumbra and two small spot areas floating on the photosphere!
2022-04-20, 83 min animation, AR12293-4, Lunt130MT, ASI290, 2x Barlow, 14_14_48 UTC by H- Alpha, on Flickr
Hope you will like it. I liked it a lot and I am happy to share the animation and my emotion about it! ;-)
Now I just hope to better seeing in the next few days to improve this kind of work on the WL.
Alexandros
And finally...
Alexandros
Alexandros
Greece
Greece
- Gordon Ewen
- Been thanked: 257 times
Re: Live floating sunspots! Penumbra ballet in 83 min animation of AR12293-4 in WL! 20 April 2022
Great stuff Alexandros.
Gordon
Gordon
Lunt 152 DSII Ha scope, Orion Optics 12" ODK, C9.25
Skywatcher EQ8 x 2
Lunt 1 1/4" Herschel Wedge, 2x,3x Barlow, 5x Powermate, Baader Ca filter and solar film.
https://www.flickr.com/photos/74614447@N02/
Skywatcher EQ8 x 2
- Has thanked: 20813 times
- Been thanked: 10487 times
These are excellent Alexandros, the WL animation is something else, stunning!
- Has thanked: 17853 times
- Been thanked: 16993 times
Alexandros,
All are great but the animation really brings the AR12993-94 area to life! It's incredible! The motion in the penumbrae of the big spots is superbly captured and just look at the seething granulation! Animations like this shows what no still image can and certainly goes huge lengths beyond my visual observations. This certainly is professional-grade!!
Two thumbs and two toes up on this one!!!
- Has thanked: 6305 times
- Been thanked: 7323 times
Beautiful images and that WL animation is just awesome!
Arne
Arne
- Has thanked: 9319 times
- Been thanked: 6157 times
Super animation and stills, Alexandros ! Good idea doing a WL animation with so much action on the surface.
- H-Alpha
Thanks a lot for your kind comments Gordon, Mark, James, Arne, Franco! :-)
I am glad you liked it.
WL animations are not common, perhaps because we need long animations to see some movement. I like WL so much. ;-)
Alexandros
Alexandros
Alexandros
Greece
Greece
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Fantastic images and animation Alexandros
best regards
best regards
Pedro Re'
- Been thanked: 4427 times
Superb images and animation Alexandros...well done
- Has thanked: 9723 times
- Been thanked: 5773 times
Excellent white light animation.
- nicspenceryork
- Has thanked: 6034 times
- Been thanked: 1310 times
Wow! Never seen a WL animation before! Love it!
How inspiring,
Nic
How inspiring,
Nic
It's boiling away!
- Has thanked: 3317 times
- Been thanked: 1907 times
Are the bright dots on the inside of the sunspot dark bits Ellerman bombs. I saw bright spot on the inside of the thin claw.
Cheers. Andrew.
Cheers. Andrew.
- Been thanked: 2725 times
Excellent images and animation Alexandros. Well done !
- H-Alpha
Thanks a lot Pedro, Brian, Rainer, Nic, James, Andrew, Christian. :-)
Alexandros
Andrew, are you referring to the Blue wing of H-alpha photo or to the animation? I suppose you refer to the blue wing (or the H-alpha), because as far as I know the Ellerman bombs are not visible in WL, although I may be wrong. Which sunspot you refer to?AndiesHandyHandies wrote: ↑Thu Apr 21, 2022 6:30 pm Hi
Cheers. Andrew.
Alexandros
Alexandros
Greece
Greece
I’ve never heard of EBs being visible in white light. Even with solar flares only really powerful ones can be seen in continuum.
Wow!! you can see the spot region drifting apart, I have never seen this before and bright penumbral grains too
