Animation of AR2975 on the 23rd March 22 10.45 UT
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Dear all,
after some time I was able to process the pictures I took on the 23rd of March, and make an animation. In this animation, 20 minutes time is compressed in 1 second. There are 10 frames each one resulting from a stack of photos taken within a 2 minutes time interval.
I still have to process another 20 minutes of photos or so...
Best, Daniele
Best, Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- Has thanked: 20240 times
- Been thanked: 10116 times
Re: Animation of AR2975 on the 23rd March 22 10.45 UT
That's great Danielle!
- Has thanked: 9082 times
- Been thanked: 5977 times
- Has thanked: 2407 times
- Been thanked: 4737 times
- Has thanked: 8355 times
- Been thanked: 8103 times
Looking good there. Nice result.
- daniele_bonfiglio
Dear all, thank you for the nice comments!
I have finalized my timelapse animation by adding 10 more frames. Now the animation covers 36 minutes of recordings. I have also rotated the image for a more natural appearance (now East is on top), added false colours, a text with minutes count and the Earth for reference to gauge the size of solar features. As in the original animation, the luminance inside the disk is inverted.
I like how the ejected plasma blobs "rain down" to the surface following magnetic field lines. In particular if you look carefully outside the disk to the right of the image there is a very faint trail of moving plasma making almost a closed loop! The tendrils of plasma waving from the active region just inside the limb are nice to see as well!
Best, Daniele
Best, Daniele
- Has thanked: 17533 times
- Been thanked: 8763 times
That's a really lovely final cut it is always interesting that most plasma movement is usually downwards rather than the expected upwards
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Daniele,
Nice work there !
How many frames per video did you take ? I am also thinking of doing animations, perhaps over a longer time frame. I will start with a few frames to work out a workflow. Did you use Photoshop actions to process the frames ?
Thanks.
Magnus
Nice work there !
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- daniele_bonfiglio
Hi Magnus, thanks! By frames do you mean frames in the animation, not frames in the individual stacks, rights? This video is composed by 18 frames each one coming from the stack of around 1000 still shots from 2 minutes long individual captures. If you want to play with it, I am happy to share the link to the Photoshop file with the animation.Boso36 wrote: ↑Fri Apr 29, 2022 6:42 am Hi Daniele,
Nice work there !
Thanks.
Magnus
https://drive.google.com/file/d/1FsZf_4 ... sp=sharing
Best, Daniele
- Radon86
Thanks Daniele,
Yes, I meant how many frames did each video file did you use.
You animated 18 frames altogether over a space of about 34mins, 1 frame every 2 minutes.
I tried to get data from SDO and the other solar websites to try out my own animations and processing. I found it hard to get the original .fits files.
Does anyone know how to get them (I was prompted to download from a ftp address), but could not find a way to download it.
I think I downloaded one of their daily movies (.avi file) and processed that by extracting separate frames etc.
Daniele, I don't know how noise free the frames are, but I was thinking I might take say 100 to 250 frames per video, and do that maybe every 30 seconds for 2-5 hours ? that would be 5x60x2 videos = 600 videos (using avi files would reduce the space and obviously taking only a ROI would help reduce the file size).
Magnus
Magnus
- daniele_bonfiglio
Magnus, my still frames (I don't make videos!) are rather noisy and so I need to stack many of them to remove noise (at the expense of a bit of sharpness maybe, but not much!). But I think that most people in this forum do what you suggest and use not many frames per video!Boso36 wrote: ↑Fri Apr 29, 2022 8:50 am
Magnus
Best, Daniele
- Radon86
Hello Daniele,daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 8:59 amMagnus, my still frames (I don't make videos!) are rather noisy and so I need to stack many of them to remove noise (at the expense of a bit of sharpness maybe, but not much!). But I think that most people in this forum do what you suggest and use not many frames per video!Boso36 wrote: ↑Fri Apr 29, 2022 8:50 am
Magnus
Best, Daniele
I came across a video on NAFE post processing by AZAstroguy. He uses a Lunt 100mm Double stack scope somewhere in North America.
https://www.youtube.com/watch?v=snbGqCmfHm0
Download NAFE from the nafe.zip file.
http://www.zam.fme.vutbr.cz/~druck/Nafe/Index.htm
Magnus
- daniele_bonfiglio
Thanks a lot, Magnus! I did not know this NAFE image processing method, it looks great! Perhaps this could be applied to the GONG H-alpha images as well?Boso36 wrote: ↑Fri Apr 29, 2022 9:03 amHello Daniele,daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 8:59 amMagnus, my still frames (I don't make videos!) are rather noisy and so I need to stack many of them to remove noise (at the expense of a bit of sharpness maybe, but not much!). But I think that most people in this forum do what you suggest and use not many frames per video!Boso36 wrote: ↑Fri Apr 29, 2022 8:50 am
Magnus
Best, Daniele
Magnus
- Radon86
Hi Daniele,daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 9:08 amThanks a lot, Magnus! I did not know this NAFE image processing method, it looks great! Perhaps this could be applied to the GONG H-alpha images as well?Boso36 wrote: ↑Fri Apr 29, 2022 9:03 amHello Daniele,daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 8:59 am
Best, Daniele
Magnus
NAFE does not remove noise, but it enhances faint details. It was optimised for 171 Angstrom solar images, but I think it gives some enhancement in H-alpha wavelength as well. I tried it on my images and it was incredible the detail and proms shown up ! The noise it generates you will have to process out.
You can use noise reduction software or Photoshop etc. I think this is better than taking a long video file as we are interested in changes, not how sharp or grain free the image is so much. That is my opinion, but I have not done any solar animations yet.
Magnus
- Radon86
Hi All,
I found this article on SDO data and how to read and obtain them. I have got the 10.5MB pdf file and will start to read this.
https://www.lmsal.com/sdodocs/doc/dcur/ ... zip/entry/
Best wishes.
Magnus
Best wishes.
Magnus
- Radon86
daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 9:08 amBoso36 wrote: ↑Fri Apr 29, 2022 9:03 amHi Daniele,daniele_bonfiglio wrote: ↑Fri Apr 29, 2022 8:59 am
Best, Daniele
I did not realise you are a Plasma physicist ! I only did Physics at A level (advanced level) and entrance exam at Cambridge University.
Magnus
- daniele_bonfiglio
Boso36 wrote: ↑Sat Apr 30, 2022 6:26 amdaniele_bonfiglio wrote: ↑Fri Apr 29, 2022 9:08 amYes Magnus, I am really lucky because I do the job was dreaming of in my childhood!
Best Daniele
