May Solar Challenge
- Been thanked: 16 times
- Has thanked: 17521 times
- Been thanked: 8763 times
Re: May Solar Challenge
I fixed it for you Andy if you press edit on your post you can see what I did
That is a very unusual one as the ejection is very bright, usually ejections are dark. That is a real monster!!
- Has thanked: 17458 times
- Been thanked: 16553 times
Alexandra is right, usually they are dark but I have seen these bright little " proms " inward of the limb being brighter than the disc on a couple of other occasions. I wish I could find the session reports on them. I usually cannot see them well with the 60 but the 90 does well on them.
Another crackling solar flare from Andy Devey
Here is a long look at the AR3017-AR3014 complex showing lots of flaring from today including an M5.6 and an M1.5 event with other C-class events. Sequence runs from 07:37 to 12:05UT.
WoW, it looks like lightning flashes in distant thunderstorms which isn't far from the truth. Just on a billions more powerful scale!
Two thumbs up!!
Two thumbs up!!
- davidem27
- Has thanked: 71 times
- Been thanked: 229 times
I think this is one of the best things I've ever seeing on solar "images".
A lot of patience.
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
GreatAttractor wrote: ↑Sat May 21, 2022 8:52 am C4.7 flare in AR 3014 from 2022-05-18 (20-s intervals, 0:24 h total):
That's an excellent animation! I saw this one visually but not near in as much detail as shown here.
Two thumbs up!
- Has thanked: 870 times
- Been thanked: 306 times
Wonderful images here - thanks all....
Call me Geoff.
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Some really good flare captures here. I got lucky last weekend with AR3011 rounding the limb and some fine seeing.
https://astrob.in/2ztihe/0/
Christopher
Nice flare animation, Christopher. Flares it seems now have become a daily phenomenon.
- OlegLviv
- Has thanked: 860 times
- Been thanked: 865 times
Sun H-alpha: Chromosphere 2022-05-04
Telescope: Apogee 127/1140mm Lunt Mod 2/BF15
Camera : Apollo Max IMX 432
Filter: Baader UV/IR Cut/L 2"
TeleVue Powermat 5X
TeleVue Powermat 5X
- ZhhLs0zaeD23_2560x0_SiQkf4no.jpg (142.22 KiB) Viewed 1457 times
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- OlegLviv
Sun H-alpha: Chromosphere 2022-05-10
TeleVue Powermat 3X
TeleVue Powermat 3X
- 09_47_44_lapl4_ap15241.jpg (548 KiB) Viewed 1436 times
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
WoW. Nice prom!!
- OlegLviv
TeleVue Powermate 2.5X
- loYdvkSBORoS_1824x0_SiQkf4no.jpg (130.15 KiB) Viewed 1410 times
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Has thanked: 9243 times
- Been thanked: 5502 times
I was lucky and the timing was right and I caught the M1.34 flare in region 3016.
It started at UTC 18.11 with c1.04 and reached maximum at 18:24 and ended at 18.43 but I stopped recording at 19:22
https://vimeo.com/713849783
Area 7 minutes before Flare started
Start 18:11 at C1.04
Maximum 18:24 M1.34
End of recording with C2.96
Maximum 18:24 M1.34
Nice work Rainer. I got the alert for it but I was completely under clouds and couldn’t see the sun at all. It was pushing worktime anyway.
Wow!! that is a double lightning looking flare it is a pity you have to log in to Vimeo to see it, is there any way to make it public?
- Been thanked: 4908 times
ALEXANDRA, THIS "MAY SOLAR CHALLENGE" ITEM, CERTAINLY HAD SHOWN SOME EXCELLENT CAPTURES AND ANIMATIONS...
I AM LIMITED TO BEING ABLE TO REPLY TO SO MANY INDIVIDUALLY, BUT I WONDER IF PERHAPS AS CYCLE #25 HEATS-UP MORE,
THAT PERHAPS TO REPEAT THIS SUBJECT IN ANOTHER "SOLAR CHALLENGE" SOON, WOULD PRODUCE MORE FABULOUS CAPTURES...
HERE'S HOPING
THANKS VM
TERRY
HERE'S HOPING
THANKS VM
TERRY
Hi Alexandra,
Sorry. Can you watch it now without logging into Vimeo ?
BTW there is a setting in phpBB which shows the videos of Youtube and Vimeo in the message itself. In my Astronomy forum Astroforo.net I just put the Vimeo or Youtube link in my message and then automatically it is shown like you can see here
Yep! it works now Rainer
Youtube yes, if you go into full editor click on the Youtube button and insert the link between the two icons. This doesn't work for Vimeo as I have tried in the past. I will ask Stephen if he can do another for Vimeo.
Hi Alexandra,
Good to hear. BTW, as I wrote, in my forum you just copy the Youtube or Vimeo link into the message and when sending it automatically the video window appears. I do not need to add any BBcode or whatever ...
Look here in the screenshot in Posting and BBcodes
- Been thanked: 1551 times
May 22nd. A lot of solar flares in the northern hemisphere around AR 3014 and 3017. Single exposure with Canon 550d attached to Lunt 100 Ha scope (SS). Cheers John W.
Nice view John.
