Saturdays C-Class Flare CaK Animation - 30th April
- Has thanked: 20957 times
- Been thanked: 10589 times
Saturday morning dawned clear, but with lots, and lots! of contrails that all got super broad super quick, filling the sky in a milky haze. I wasn't optimistic at all if i'm being honest, but it was the best I was going to get over the bank holiday weekend with Sunday and Monday forecast cloud and rain.
I started off with the 100/800 APM scope stopped down to 80mm, as that was my finger in the wind in terms of seeing given the conditions. It turns out I was pretty spot on, and I think if i'd used 100mm aperture the frames wouldn't have turned out. Using the Airylab 2.7x telecentric to get the scope up to f27, and the ZWO290mm camera, I find if i've got the aperture right for the seeing then this is a combination with real synergy.
The haze was thick, and I had to increase exposure time to 10ms (much longer than I like) and had to crank the gain up to around 40% (which is also higher than I like!) to get a decent histogram. But. imagine my surprise when I scooted around the disk for a target and found a flare happening just off the limb. Seeing these things before I decided to run a timelapse, and ran off 19 frames between 07.31ut and 07.48ut. On reflection I should have probably ran off a few more, but I wasn't convinced with the haze it wouldn't be any good. Looks like I was wrong and the result turned out OK!
CaK-ani-wide-bw by Mark Townley, on Flickr
CaK-ani-wide-colour by Mark Townley, on Flickr
Has been ages since I bagged a flare, and a while since been able to do an animation!
Hope you like.
Hope you like.
- Has thanked: 8588 times
- Been thanked: 8324 times
Re: Saturdays C-Class Flare CaK Animation - 30th May
Superb, Mark. Simply awesome
- Has thanked: 2501 times
- Been thanked: 4926 times
- Has thanked: 987 times
- Been thanked: 349 times
Excellent capture and, going by your story, a true lucky capture!
Call me Geoff.
- Has thanked: 3329 times
- Been thanked: 1907 times
Thanks everyone! I also got these closeups, same kit 80mm f27 290mm, not quite as dramatic as the flare though
ar13001-CaK-80mm-f27-290mm-bw by Mark Townley, on Flickr
ar13001-CaK-80mm-f27-290mm-colour by Mark Townley, on Flickr
AR12998-CAk-80mm-f27-290mm-bw by Mark Townley, on Flickr
AR12998-CAk-80mm-f27-290mm-colour by Mark Townley, on Flickr
I think I got it right in terms of the seeing to image at 80mm aperture; the penumbral fibrils are just about resolved, the images above are the best of the batch, and the discarded ones don't show the fibrils resolved. The APM100/800 is a good performer in CaK, and if you are interested how it compares to the much cheaper Tal, check out this thread viewtopic.php?f=10&t=35925
- Has thanked: 60 times
- Been thanked: 34 times
Fantastic flare animation and great write-up comparing the Tal to the APM..nice one mark
- rigel123
- Has thanked: 8663 times
- Been thanked: 8896 times
Great animation Mark, it really did turn out well despite the conditions you described!
- Has thanked: 9387 times
- Been thanked: 6199 times
First CaK animation of a flare I see, very well done Mark ! The stills are great too. The 100mm f/27 stopped down is working well for you.
- JochenM
- Been thanked: 1619 times
Thanks everyone! The only thing left from the session was the full disk
Cak-FD-60mm-f16-ICX814-bw by Mark Townley, on Flickr
Cak-FD-60mm-f16-ICX814-colour by Mark Townley, on Flickr
- Has thanked: 18105 times
- Been thanked: 8941 times
These are absolutely awesome Mark
But I'll let you change the title to the 30th April how many beers did you have
Re: Saturdays C-Class Flare CaK Animation - 30th April
Ha ha ha! Date changed and thanks for the SPoD. Think it was morning coffee not beers that made me get the date wrong
- Been thanked: 2725 times
Splendid Mark !
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Fantastic Mark!
Congratulations for this excellent capture and SPOD!
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 1640 times
- Been thanked: 878 times
Holy cow a calcium flare animation is freaking awesome!
- Been thanked: 5016 times
Mark:
Super Flare animation and images.
Thanks for sharing your work.
- Has thanked: 65 times
- Been thanked: 4460 times
These are all excellent images Mark and the flare is a super catch
- Been thanked: 1648 times
Worthwhile captures Mark - well done. Cheers John W.
Thanks everyone for the lind comments, hopefully some clearer skies later in the week and at the weekend.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Wow Mark , that's am amazing animation.
Martin
Martin
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Fantastic work Mark!
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
Thanks guys! No sun here till the weekend for me, but some astro goodies on route so a month of cloud may be on the cards
- Has thanked: 6353 times
- Been thanked: 7411 times
Fantastic animation, Mark! This is so cool to watch!!
Big congrats on the SPOD as well!
Arne
Arne
