Images today taken with Takahashi 76DC, Televue 4x, Daystar Quark, DS PST Etalon, QHY 174mm.
Processed in ImPPG and then unsharp mask in Photoshop
I tried again today, this time with tilter and the result improves a lot. On yesterday attempt I didn't use a tilter because I thought I could eliminate the newton rings by the thin plastic bag flat approach - obviously I was wrong. It requires to tilt (quite a lot), and also the flat plastic bag in order to get these results.
I used a ZWO tilter, and the only small problems encountered was the adjustments screws are too short as I need to tilt quite a lot. I'm going to order some longer screws to have the tilter position fixed well.
6/May/2022 Ha Images
- Has thanked: 230 times
- Been thanked: 176 times
- Has thanked: 9319 times
- Been thanked: 6157 times
Re: 6/May/2022 Ha Images
These look great! It looks like you have solved the problem.
Beautiful images...
Beautiful images...
- Has thanked: 17853 times
- Been thanked: 16992 times
Nice work. These look really good.
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Looking good!
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 6305 times
- Been thanked: 7323 times
