Double stacked continuum filters
Sol seeker uk
Has thanked: 60 times
Been thanked: 34 times
Post by Sol seeker uk »
Hi all, just had a look at purchasing a continuum filter for white light imaging as it's said to give slightly better contrast, when I see a double stacked version.. it gives a slight tilt to each other, anyone use one and can give abit of feedback? Are they any better than the single filter versions?
https://www.widescreen-centre.co.uk/baa ... -here.html
Has thanked: 20757 times
Been thanked: 10444 times
Re: Double stacked continuum filters
Don't waste the extra money on the double stacked version its a gimmick.
Sol seeker uk
Thanks Mark, didn't know they existed until today
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
A continuum filter is a filter which isolates a small part of the solar spectrum where there is no strong spectral lines. So the name "continuum", meaning "constant" or "steady".
Accordingly, because there is no spectral line to be isolated, there is no need to have a very narrow band pass.
BTW, there are many "continuum" windows (and filters) : 668 nm, 555 nm, 450 nm, 432.2 nm, etc.
If we want to give a full answer to this, this is true that professionals use narrow "continuum" filters (in the range of 0.5 to 0.3 nm FWHM). This is because they want to sample spectral windows with no line at all.
This is not a concern or a benefit for the amateurs. 10 nm filters are OK for us.
So the recommendation of Mark :-)
BTW, deep sky Ha, OIII, Hbeta filters are quite usefull for solar imaging. Using this kind of filters reduces atmospheric dispersion and instrumental chromatic aberration (is any).
Sol seeker uk
Thanks Christian for your detailed answer
