Hi folks,
I get a strange behaviour in Autostakkert3!
Every SER-File i am recording creates a strange red border in AS3. Most of the time the are with image dta is only the right bottom quarter of the screen. The live image is full size nevertheless. It only happens in AS3.
This effect is independent of following parameters:
- change of USB ports: no change
- using different cameras: ASI174MM, ASI178MM, Touptek IMX183MM: same behaviour
- using different USB cable: same behaviour
What made a difference:
- using a different PC: perfect.
The SER-files are correct... SER players show all data.
Does anyone have an idea?
Weird behaviour of AS3!
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
- 00003.jpg (56.69 KiB) Viewed 1434 times
- Petrus
- Has thanked: 1496 times
- Been thanked: 684 times
Re: Weird behaviour of AS3!
What setting do you have on image stabilization? I get results like this if it is Planet instead of Surface.
Also, I got similar results if tracking was bad (wind, casual knock on the mount...)
~ Petrus ~
Flickr
Flickr
- Has thanked: 2978 times
- Been thanked: 2082 times
Looks like you didnt select the "crop" option at the image stabilization options.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Bastelhannes
Good hints; I am going to try...
- Bastelhannes
This is the solution.. I really did this mistake!
Thank you so much!
- Petrus
Great! I'm glad I could offer help
~ Petrus ~
Flickr
Flickr
