Active Regions in Ha 12th May 2022
- Has thanked: 8559 times
- Been thanked: 8291 times
ARs 13006 & 13007 in hydrogen alpha on my 150mm scope at f35 using a 2.5x PM and Basler acA1920-155 um.
The seeing conditions were okay at the start of the session at 9:20 UTC (for AR13007) but within 30 minutes of scudding clouds and fishing in the gaps the seeing turned south really dramatically.
Anyhow, here are the results. AR13006 flaring again.
Okay seeing:
20220512_Ha_AR13007 by Stuart Green, on Flickr
Less than optimal seeing:
20220512_Ha_AR13006_mono by Stuart Green, on Flickr
...and a three frame mosaic across the same region...
20220512_Ha_AR13006_Mosaic by Stuart Green, on Flickr
Thanks for looking.
Okay seeing:
Thanks for looking.
Re: Active Regions in Ha 12th May 2022
Many thanks, Freddie.
- Has thanked: 17853 times
- Been thanked: 16998 times
Nice closeups Stu!
JP
JP
- Has thanked: 3058 times
- Been thanked: 2161 times
Nicely done and great details,
what kind of h-alpha filter is it?
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6305 times
- Been thanked: 7324 times
Fantastic images, Stu! You did a great job fishing between clouds!
Arne
Arne
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Superb images Stu.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Been thanked: 4980 times
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Great capture of 3006 in action Stu!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 9326 times
- Been thanked: 6157 times
Thank you very much, everyone.
Hi Dennis,
The ‘Ha filter’ is a pair of rear mounted Lunt 35 etalons working together with a Coronado BF15.
- Been thanked: 10489 times
Missed these, they came out well Stu!
Thanks, Mark.
