Had chance of grabbing a few images this morning thanks to a short gap in the clouds between 11:18 and 11:20 UT using my Helios re-spaced 150 f/8 (stopped down to 100mm) with Lunt CaK B12 module and QHY5III 178M (using ROI) Main aim was to get an image of AR 3007 as it shows yet another transformation since I last imaged it on the 14th. Second image shows AR 3011,3014 and 3015 and the third showing sunspot group AR 3010.
SER files stacked in Registax 6,wavelet sharpened in Astrosurface and final processing in Photoshop CS2,seeing was unsteady and wind was shaking the scope at times.
Alun
CaK images 16th May 2022
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 8537 times
- Been thanked: 8267 times
Re: CaK images 16th May 2022
Nice images, Alun.
Lots of complexity in these active regions, which bodes well for more flare activity.
- Has thanked: 20767 times
- Been thanked: 10452 times
Nice CaK shots Alun!
- Has thanked: 6276 times
- Been thanked: 7302 times
- Alun_H
Thank you for your kind comments guys!
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
