Dear friends,
Constitution day here in Norway and sunny all day! Spent the morning doing the regular FDs under very transparent skies and medium seeing.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a SkyWatcher SolarQuest.
FD image in CaK using a FLO StellaMira 80mm ED f/10, stopped down to 60mm, Lunt CaK 1200 module and ASI 183mm camera mounted on a SkyWatcher SolarQuest.
FD image in Continuum using a FLO StellaMira 80mm ED f/10, Baader 2" UV/IR, Lunt Herschel Wedge, Baader 1,25" Continuum and ASI 183mm camera mounted on a SkyWatcher SolarQuest.
Click on images to view them in full size on AstroBin.
I did some high-res and timelapse recordings as well in the afternoon, but haven't had the time to go through or process these yet.
Arne
Sun FD in H-Alpha, CaK and Continuum 17th of May 2022
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 4786 times
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Re: Sun FD in H-Alpha, CaK and Continuum 17th of May 2022
Superb set of full disks Arne.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 20424 times
- Been thanked: 10243 times
A pleasure to see Arne!
- Has thanked: 9144 times
- Been thanked: 6025 times
You always do a great job Arne. Thank you for posting.
