A little outburst was noticed while observing for public took place and I caught some of the burst on the edge.
Image was taken with Baader D-ERF + TEC 140FL + Baader TZ-3 + Solar Spectrum RG38 0.5A + TeleVue Powermate 2.5x + Player One Apollo M max.
2022-05-19-1225_7-U-L-Sun_Halpha_Apollo-M-MAX_g3_ap1317r6r by Alan Jadanic, on Flickr[/url]
Little outburst 19th of May, 2022
- Has thanked: 20940 times
- Been thanked: 10587 times
Re: Little outburst 19th of May, 2022
Lovely capture!
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Superb!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 9379 times
- Been thanked: 6198 times
- Has thanked: 17949 times
- Been thanked: 17093 times
Looks like a surge prom!?
Nice!
Nice!
- Has thanked: 6353 times
- Been thanked: 7408 times
- Lagonda
- Been thanked: 178 times
Yes, it was a sudden surge. A friend of mine noticed that visually and I put the camera on my scope and capture some of it.
- Has thanked: 8588 times
- Been thanked: 8324 times
Nicely imaged. You got lucky, but made the best of the opportunity. Great work.
Lagonda,
You can improve your setup performance if you change it a bit.
As I see, your SS RG38 0.5A works at telecentric beam @F/21. This is far not optimal F/D for realization of the etalon potential. The slower F/D, the better. So, if you will place a TVPowerMate2x before the TZ3, then your SS etalon will work at F/42 which is so MUCH better. Images should be significatly more contrasty with better shades in low contrast areas.
With this changes you will no longer need 2.5x Barlow in front of the camera.
Hope this helps.
Hope this helps.
- Lagonda
Hi Valery, thank you for the info. I have variable iris in front of D-ERF filter and it is 113mm. So I get f/26. The reason why I am using TZ-3 instead of TZ-4 is to get full disc for visual observing. I am waiting TZ-4 along with some other SS filters to reach f/30 and even more. Now I have M68 tele compendium (tubes where you put TZ-system) and I have to see what are the options to put Powermate in it. But I don't think this is possible with M68 compendium. For imaging there are many ways of getting bigger image along with different camera sensor sizes.Valery wrote: ↑Thu Jun 23, 2022 1:53 am Lagonda,
Hope this helps.
I will look into it and see if I could put some Powermate before filter. I really appreciate your comment.
Best regards
Alan
