A lonely AR with sunspots this morning, sprung up from nowhere! Should be AR 3029 if I am not mistaken.
Humidity was a whopping 78% this morning, which meant I had to push my Gain from the usual 100 - 110 to nearly 200 to punch through the haze.
Anxious to see if 3014 shows up and still active (should rotate to view from far side of the sun in a couple of days, fingers crossed!).
Sol FD WL 2022.06.09
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 20828 times
- Been thanked: 10499 times
Re: Sol FD WL 2022.06.09
Wowzers! Love it with the sun - blink and you miss it, was blank when I went to bed last night Going to head out with the sunoculars shortly to check it out.
Nice disk Nick, thanks!
- nicosolcy
Cheers Mark! I have the Celestron "Sunoculars" but the detail provided is tiny due to image scale (low magnification).
But it is certainly better than lugging out a scope for a quick look!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 17856 times
- Been thanked: 17003 times
That's the idea... :-)But it is certainly better than lugging out a scope for a quick look!_nicosolcy
- Been thanked: 4881 times
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 8907 times
- Has thanked: 6305 times
- Been thanked: 7327 times
