Prom: ASI174MM, prom quark & SW Evostar 80
- nicspenceryork
- Has thanked: 6034 times
- Been thanked: 1310 times
Re: Prom: ASI174MM, prom quark & SW Evostar 80
Okay, watch this space then, I’ll do a short video specifically on the colour composite part of the processing in the next couple of days! ☀️🟠🔵
Nic
Nic
This really is a fab image Nic
I did a blue sky once in the past but I have absolutely no idea how I did it I look forward to the tutorial
- nicspenceryork
For your amusement, my first ever YouTube video showing how I did the composite colour image.
Beginners, it's a great base to work from.
Experts, you'll cringe with where I go wrong but do tell me so I can improve!!
Enjoy,
Nic
Enjoy,
Nic
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Geia sou Nic,
you caught the texture very nicely. Incredible combination of colors. Excellent Work!
I will buy a camera!
Marios S.Ioannou
Sketcher/Visual Observer
- JochenM
- Been thanked: 1619 times
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Dear Nic,
thank you very much for the nice picture and for the tutorial!
Let me share my experience with dealing with two colours. In the attached screenshot you see a Photoshop window, where I make an orange disc (including orange proms) on top of a light blue sky background.
Basically I duplicate the image (already modified with ImPPG) and use one layer as the background by Gaussian blurring the disc, putting a layer mask in correspondence to the limb, and using the "screen" blending mode. The other layer is a standard false colored Sun with black background.
I'm pretty sure the same result could be obtained with GIMP as well.
Best, Daniele
Best, Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- Has thanked: 1640 times
- Been thanked: 878 times
Nic, can you put this in a separate topic then I will put in the library
- nicspenceryork
Hello, I am new to this and was searching the site for tutorials. It looks as though the video from Nic has disappeared from the thread. Is it still available somewhere?
Thanks,
Bob T.
Thanks,
Bob T.
The link to this is also in the Solar Reference Library where there are lots of tutorials available viewtopic.php?t=36650
However, it looks like Nic has removed the video from YouTube
- nicspenceryork
So sorry for the inconvenience of removing the video Bob. For some reason I couldn’t find this original post on solarchat either so was unable to delete it, hence this situation, sorry!
When I finally got my head around processing and equipment I realised that the video was misleading in parts, and in addition to being cringeworthy and too long, I decided the best thing for it was the bin! A good chunk of my learning was based on these two YouTube videos, trial and error and 100% determination! Now I’ve learned to process I use the tricks learned to present the more natural, positive (non inverted sun) which is very much more my preference.
Do get in touch if I can help with anything after you have seen the videos.
Good luck with it,
Nic
https://youtu.be/-zD4EIGBess?feature=shared
https://youtu.be/G-41RMTCdTE?feature=shared
Good luck with it,
Nic
