14.06.22 AR3032 in H-alpha (closeups)
- Has thanked: 3060 times
- Been thanked: 2163 times
the next interesting sites are coming around and i had a close look to the area of AR3032, after improving collimation of the C9 further last night.
This time i used a 3x TV barlow instead of a 2x for more precision with the collimation.
Sadly after finishing the todays solar imaging session i realized that the camera wasnt seated properly inside the 2" Quark adapter. So i hope to fix most abberations by improving this next time.
The Scope was at ~F36 with the Daystar reducer and at ~F45 without it.
Thanks for looking.
Thanks for looking.
- MG_Dennis_C9Tri_220613.png (15.31 KiB) Viewed 579 times
- MG_Screen_Dennis_C9Tri_220613.png (151.5 KiB) Viewed 579 times
- IMG_20220614_074539.jpg (1.34 MiB) Viewed 579 times
- 0550_5__.png (1.26 MiB) Viewed 579 times
- 0535_3__.png (1.25 MiB) Viewed 579 times
- 0456_8_.png (1.35 MiB) Viewed 579 times
- 0447_2_.png (1.26 MiB) Viewed 579 times
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Been thanked: 4881 times
- Has thanked: 716 times
- Been thanked: 659 times
Re: 14.06.22 AR3032 in H-alpha (closeups)
V nice. Is the visual something similar to that? (Have always wondered). Btw I see you use a MiniTower too - great to see it takes a C9 without a sweat. That's a nice idea about the foil to protect the mount - I've just copied your approach here
Thx, i dont know, i havend tried yet. But i also dont have high hopes there since i see this apertures more in the realm of imaging only.
Its the alt az pro, works fine with the C9 for solar system imaging and visual.
Yes, i made that little hat because the mount got really hot up there without it : )
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Been thanked: 8907 times
Wow!! can you give me a little more detail on how you are collimating? I see nothing at all like these images with my C11
- Has thanked: 6305 times
- Been thanked: 7327 times
Excellent results, Dennis!
I particularly liked the 3rd image (0456_8_.png).
Do you find it easy to achieve good collimation using MetaGuide?
Arne
Arne
Sure, first i make sure i am as close as possible to collimation by centering the defocused starpattern (donut). The donut has to be in the center of the field of view, and once it moves because i turn a collimationscrew i center it back to the middle. This first procedure is usually not necessary for me after i did it one time.
Then i use Metaguide (free tool with manual on its website) and do the finetuning. I center a bright star thats relatively high in the sky and bring it to focus with the help of a focusing mask (Firecapture). Then i switch to Metaguide to see how well it is collimated (red dot helper). Once im fine i do the same with higher maginification, in my case a 3x barlow with the apollo max. Same procedure, small turns and after each turn center the star to the middle.
It takes a while to get used to the software and its settings. After that, its a breeze to do the routine.
"I see nothing at all like these images with my C11 "
Im still learning to image with the C9, but i think its rather about imaging/processing techniques combined with decent seeing then the best collimation. The TZ4 was the partypooper last time you showed C11 images i think.
Im still experimenting with imaging times and fps, i sense a lot of potential here.
Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Thank you Arne.arnedanielsen wrote: ↑Tue Jun 14, 2022 5:17 pm Excellent results, Dennis!
Arne
I would lie if i said it was easy the first time with MetaGuide. Now that im used to it it is actually a very fast routine that i do once every 3 months or so to check collimation. Often it is still spot on.
regards
Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 20834 times
- Been thanked: 10502 times
Nice results Dennis!
Your observing location on that balcony seems a lot more seeing friendly than mine, and I admire your collimation prior. Personally, I can't be fussed with all the collimation involved (not just for solar!) to make them perform and then the variability with mirror flop etc. Give me a frac any day!
Thanks Mark.marktownley wrote: ↑Tue Jun 14, 2022 8:02 pm Nice results Dennis!
dont worry, i did this only to get it right because i had it new.. now it will stay like that for quite some time.
Im also a fan of refractors, but not of a 235mm one : )
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- JochenM
- Been thanked: 1619 times
The joys of collimation Collimated my C9.25 last week as well (just for nighttime visual use though); it does get easier the more you do it indeed.
You seem to have everything set up perfectly though. Very nice results!
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very nice images!!
Marios S.Ioannou
Sketcher/Visual Observer
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Fantastic images
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- rigel123
- Has thanked: 8589 times
- Been thanked: 8823 times
Those are great shots!
- Has thanked: 9327 times
- Been thanked: 6163 times
Thank you all for your nice comments.
This device is a lot of fun and thermally not as hard to handle as i thought. Quite the opposite.
Imaging and processing a bit different though.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 1640 times
- Been thanked: 878 times
