It was a scorcher yesterday 6/13/2022
- rigel123
- Has thanked: 8314 times
- Been thanked: 8540 times
Heat index was 99F when I started and 103F when I said "Enough!" Sky was pretty soupy although seeing was fairly steady. Had horrible banding and Newton Rings for some reason which I typically don't need to worry about. May need to try clocking my DS as well as trying out my tilt adapter too in this hot weather! Lunt LS60T DS, ASI174MM, Meade 3X Tele-extender for closeups.
Full Disk ARs 3030, 32, 33 inverted 15 minute animation of the SW limb, not sure what AR might have been firing off those little surge proms on the limb. Rotated 90 degrees CCW for viewing:
SW Limb Animation 6 13 2022 by Rigel123, on Flickr
- Has thanked: 20437 times
- Been thanked: 10245 times
Re: It was a scorcher yesterday 6/13/2022
Sounds a bit hot for me Warren! The results came out well considering though.
Do you use the same processing settings on your full disk as the closer views?
- rigel123
Thanks Mark, I don’t think I use the same processing settings ever, they are forever changing!
- Has thanked: 9145 times
- Been thanked: 6025 times
Nice work in the extreme heat, Warren. I would not be able to stand it: I prefer the cold
- Has thanked: 1640 times
- Been thanked: 878 times
- rigel123
Thanks Franco and Alan!
- Been thanked: 16694 times
Here in western North Carolina we reached 90F yesterday and 86F today. Fortunately I usually observe the sun before we reach the daily high temperature. Out of the mountains in SC and eastern NC they have had temperatures above 95F. ( 35C ). Tomorrow we are forecast to hit 94F and the lower elevations outside the mountains may hit 100F or above ( 37.7C ). As I type this at 1:37am EDT it's 77F ( 25C ) outside. Unusually warm for so late at night. I am glad I have air conditioning.
- JochenM
- Been thanked: 1619 times
I'm getting overheated just reading that
Nice results all the same.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful images Warren!
Marios S.Ioannou
Sketcher/Visual Observer
- rigel123
Thanks Jochen and Marios! Supposed to hit 96 again today with 110 heat index. It’s 6:17 EDT and 77 so going to set up for a quick morning session before it gets brutal again!
- Been thanked: 8791 times
Great shots and ani Warren the full disc looks a little off band, I usually find newtons rings are much worse the more off band you get. Perhaps it is the air pressure/heat?
We are predicted to get one hot day on Friday, 27 degrees!! then back to 18 on Saturday
WooHoo!! let's enjoy it!!
- Been thanked: 4904 times
- rigel123
Thanks all! Alexandra, not sure if it was offband or the processing to try and pull stuff out of that soupy sky! I played with that image more than I typically do and don’t think I did myself any favors in doing so!
- Has thanked: 6181 times
- Been thanked: 7142 times
- rigel123
Thanks Arne
- nicspenceryork
- Has thanked: 5856 times
- Been thanked: 1256 times
Great images and animation Warren. Love the little dancing surge proms and the goldfish mouth opening and closing bottom left!
'Hats off' to you for persevering in the heat. Being a redhead, my hat was firmly on and I started melting at 26°C imaging the spots in WL yesterday.
Nic
Nic
- rigel123
Thanks Nic! My hat was on and I was under the Telegizmo Solar blanket too!
- Gordon Ewen
- Been thanked: 257 times
Hi Warren, I like your animation. We had a hot one (33C) today, its too hot! As is often said in the UK, keep calm amd carry on.........
Gordon
Gordon
Lunt 152 DSII Ha scope, Orion Optics 12" ODK, C9.25
Skywatcher EQ8 x 2
Lunt 1 1/4" Herschel Wedge, 2x,3x Barlow, 5x Powermate, Baader Ca filter and solar film.
https://www.flickr.com/photos/74614447@N02/
Skywatcher EQ8 x 2
- Has thanked: 8418 times
- Been thanked: 8162 times
Nice work, Warren, in challenging conditions. Lovely animation.
- rigel123
Thanks Gordon and Stu!
