Tuesday Sunshine 14th June
- Has thanked: 20824 times
- Been thanked: 10498 times
Tuesday was nice and sunny with blue skies and decent transparency with temperatures in the low to mid 20's I decided to get home early from work with a view of a bit of observing / imaging, seeing was coming in on meteoblue at >2" so I decided to play safe and come away with treasure rather than trash. A bit of 'exploring' here with some different setups, firstly the full disk in Ha, double stacked 50mm on the 60/360 scope with a 2x cemax and the 183mm camera using 2x2 binning to hone in on the sampling rate.
Ha-FD-DS50-2x-cemax-zwo183mm-2xw-binning-bw by Mark Townley, on Flickr
Ha-FD-DS50-2x-cemax-zwo183mm-2xw-binning-colour by Mark Townley, on Flickr
I like 2x2 binning here (compared to not) - exposure time with the DS shortens to 3ms. Files take up less disk space and take less time to process. I'm certainly going to explore more!
Next up the CaK full disk, this time using the ED80 stopped down to 40mm to give a f15 light cone through the filter. For the homebrew filter this f15 seems to give best results (more stop down masks to be made on the laser cutter I think for other scopes)!
CaK-FD-40mm-f15-IMX183mm-bw by Mark Townley, on Flickr
CaK-FD-40mm-f15-IMX183mm-colour by Mark Townley, on Flickr
I'm hoping you like these and also hoping I get clear skies before work on thursday for another quick view!
MArk
MArk
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Re: Tuesday Sunshine 14th Jun
Hi Mark
Really nice images, always love your Cak images
I have been stuffed with interviews and training, will,likely get out on the 16th weather forecast is good and the active areas look great, seems to be a little quite following these when they have passed
Going to run up the Apollo Max
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Ibbo
- Has thanked: 2443 times
- Been thanked: 1650 times
Re: Tuesday Sunshine 14th June
We must have been out at nealy the same time for the Cak.
Nicely done Mark.
Nicely done Mark.
- rigel123
- Has thanked: 8583 times
- Been thanked: 8819 times
Gorgeous disks Mark! BTW, 20C sounds great after our few days at 35 and higher!
- Has thanked: 17855 times
- Been thanked: 17003 times
Mark,
Really nice! You got good detail on both Ha and CaK. Very nice coloration too!
James.
James.
- Has thanked: 9327 times
- Been thanked: 6163 times
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Lovely disks - CaK does it for me pretty well!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- JochenM
- Been thanked: 1619 times
Looking good, Mark.
Binning the ASI183 in that setup does seem to give very pleasing results.
Thanks everyone, I do have some closeups but need to finish processing them, hopefully that will be this evenings job.
- Has thanked: 8559 times
- Been thanked: 8297 times
Very nice FDs, Mark. Sometimes it’s best to play it safe when the conditions are marginal. Opportunities are too few to waste.
Binning without losing the available resolution is definitely worthwhile and given the shorter exposure times it can only help when the seeing is borderline.
- Been thanked: 8907 times
Great shots Mark cloud again here in Cheshire, are we in the only cloudy place?
- Has thanked: 6305 times
- Been thanked: 7327 times
Thanks everyone for the kind words, it's cloudy here too ALexandra, at least when I can observe :/
Here are the 'closeups' I promised. I say this 'in a fashion' as the disks are already critically sampled so by switching to the 290mm camera and altering the barlow power just offers a different presentation. I could probably crop down from the disks and things wouldn't be much different...
sw-quad-Ha-DS50-f15-zwo290mm-colour by Mark Townley, on Flickr
sw-quad-Ha-DS50-f15-zwo290mm-bw by Mark Townley, on Flickr
ols-ar-cak-40mm-f22-zwo290mm-colour by Mark Townley, on Flickr
ols-ar-cak-40mm-f22-zwo290mm-bw by Mark Townley, on Flickr
New-AR-CaK-40mm-f22-zwo290mm-colour by Mark Townley, on Flickr
New-AR-CaK-40mm-f22-zwo290mm-bw by Mark Townley, on Flickr
Eastern-Activity-Ha-DS50-f15-zwo290mm-colour by Mark Townley, on Flickr
Eastern-Activity-Ha-DS50-f15-zwo290mm-bw by Mark Townley, on Flickr
ar13030-Ha-DS50-f15-zwo290mm-colour by Mark Townley, on Flickr
ar13030-Ha-DS50-f15-zwo290mm-bw by Mark Townley, on Flickr
ar13030-CaK-40mm-f22-zwo290mm-colour by Mark Townley, on Flickr
ar13030-CaK-40mm-f22-zwo290mm-bw by Mark Townley, on Flickr
I've been hoping to observe a bit more this week but the weather has been pants at the wrong times. I want to explore the 183mm with 2x2 binning a little more, next full disks I may try recording in 16 bit and see how this comes out (apart from longer processing time than 8bit), i'm wondering if 16 bit (well 12bit really!) will get me any more with the increased well depth the binning offer compared to non binned. I do like a tinker! Anyway, unless it is clear first thing in the morning before work I won't be imaging till next week with rain forecast for the weekend.
Hope your weekend offers better and hope you like these shots!
Very nice Mark and I always like your shots!
Good luck on a better solar weekend.
P.S. What are the little white dots in the plage in the CaK images? Do EBs ever get picked up in CaK or CaH images?
Thanks James, I think it is micro flaring, either way it is common on the active sun.DeepSolar64 wrote: ↑Thu Jun 16, 2022 9:42 pmWhat are the little white dots in the plage in the CaK images? Do EBs ever get picked up in CaK or CaH images?
Nothing wrong with a bit of tinkering, Mark.
It will be interesting to see your results.
By what I can gather, Mark is a tinkerer!!
- nicspenceryork
- Has thanked: 6087 times
- Been thanked: 1321 times
I can barely believe my eyes, these are SUNsational!
I've just commented to Arne, and the same goes to you with this set, that I was telling my friend about your images and how all the detail stays when you zoom in. What factors help this? Camera? Scope? SER bit number? Or straightforward superhero special power?
Nic
Nic
Thanks Nic, the only think i'm doing here is making sure the sampling is correct - wavelength, focal length, pixel size that's allnicspenceryork wrote: ↑Fri Jun 17, 2022 3:57 pm I've just commented to Arne, and the same goes to you with this set, that I was telling my friend about your images and how all the detail stays when you zoom in. What factors help this? Camera? Scope? SER bit number? Or straightforward superhero special power?
