Hello again..
I could again ckeck on the bog prominence that i started to observe this morning....but this time , as I had more time to image the sun I (again) tried both gratings in my spectro coronagraph..and guess who won the resolution contest..?
I let you judge....
Chris
proms of today June 16th 2022...evolution and comparison
- Has thanked: 259 times
- Been thanked: 237 times
Re: proms of today June 16th 2022...evolution and comparison
With the 1200 lines/mm the image is "squashed" that its more blurry as each point of the image is more stretched due to higher dispersion.....
This works only if you use the "wide slit method.
Chris
Chris
- Has thanked: 17523 times
- Been thanked: 8763 times
The first image is absolutely spectacular, so clean and detailed. First class!!
awwwwwwwwww thank youuuuuuuuuuuuuuuu
the first image is the one produced with the 600 lines/mm grating .... there is less anamorphose (almost none) and less dispersion so its sharper.
