Spent large portions of the day baking in the sun, doing visual & imaging. Will post HA report separately, but for WL I tried a different set-up. A v old Meade ETX125 w Baader AstroSolar 5.0 film (ie not the photographic version). Images below. Have to say I'm v pleasantly surprised by the film vs the wedge. Will try and do a proper side-by-side visual comparison later (alternating both on my old SP102) but the film was doing pretty well - the weak point was the single-speed focuser on the ETX - really need to somehow improve that (watch this space).
All in all v pleased with it. On the SP102M + Lunt wedge, there were times in the morning when even 333x was ok! But spent most of the time at 200x.
With the ETX+film, 211x was a doddle, 317x was fine, it was holding it at 380x and in moments even 470x! But the image was quite dark at the higher magnifications & the focuser limitations were really apparent at those levels. The ND5 apparently only lets 0.001% of light through, while by my calcs a wedge + ND3 let through 0.004%? Now I reckon 3.8 film + ND0.9 would let through 0.002%?
Form factor wise, the shorter Mak much easier than a long achromat - but I really want to do a like for like comparison of film vs wedge. I know wedge is meant to be better, but I'm curious whether I will notice much difference w my eyes.
Cheers,
Vin
17 Jun WL
- Has thanked: 696 times
- Been thanked: 648 times
17 Jun WL
- Sun_121719_170622_ZWO ASI224MC_Gain=60(off)_Exposure=.6ms_WL_ETX125_ND5_642nmfilter_5_qe4_ap2351_imppg(220426WL)_gimp_wm.png (776 KiB) Viewed 350 times
- Sun_122358_170622_ZWO ASI224MC_Gain=60(off)_Exposure=.6ms_WL_ETX125_ND5_642nmfilter_3_qe4_ap567_imppg(220426WL)_gimp_wm.png (411.34 KiB) Viewed 350 times
- Sun_122756_170622_ZWO ASI224MC_Gain=60(off)_Exposure=.6ms_WL_ETX125_ND5_642nmfilter_3_qe4_ap704_imppg(220426WL)_gimp_wm.jpg (54.88 KiB) Viewed 350 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: 17 Jun WL
The thing I like about the wedge is by turning the polarizer the brightness of the image can be controlled. This is especially important at high magnifications.
I only rarely ever have seeing that will allow 200x, much less 300x or higher. That’s incredible! For me 100x plus in the daytime is a thrill!!
Re: 17 Jun WL
Likewise. Most of the time lately it's been mush from 200x and above (sometimes even pretty bad at 160x, generally pretty consistently ok at 110x). So I couldn't quite believe it when I saw the image holding together - albeit very fleetingly at the highest mags, but still I'll take it!DeepSolar64 wrote: ↑Fri Jun 17, 2022 9:43 pm
I haven't tried a polariser in a wedge yet - will have to do that & report back.
Cheers!
Re: 17 Jun WL
Many wedges come with a polarizing filter. Mine came with one already built in. If it doesn’t one can be screwed into the bottom of an eyepiece and then you turn the eyepiece to adjust the brightness.
Your seeing certainly is better than mine!!
- Been thanked: 10248 times
Re: 17 Jun WL
Nice shots there Vin!
Re: 17 Jun WL
Thanks Mark, that's v kind. I was quite surprised by the results vs a wedge - although I'm sure the 642nm long-pass filter & high FPS of the 224MC helped a lot. I was using an old laptop so it was only USB2 speeds as well.
