June 19 2022 Imaging session!
- Has thanked: 17920 times
- Been thanked: 17065 times
My session time was from 15:30 until 16:40 UTC. The skies were mostly clear but had some high clouds. The seeing is below average and the temperature at session's end is 76F ( 24.4C )
I imaged today using the SMII90 in both SS and DS in Ha and with the C102 in WL. I used my Windows 8.1 laptop with the ZWO ASI178MM monochrome camera. SharpCap was used for image acquisition and AVIStack for image stacking. GIMP and Paint.net was used for editing/processing.
I hope you guys and gals like them.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Re: June 19 2022 Imaging session!
Great post James, I really like the proms , the colouring is really good.
Thanks Martin. For some reason I seem to do better with imaging proms than I do the disc. I think it's because I can focus easier on the proms. I usually image proms first now and focus using them.
I used RGB curves in GIMP to do the coloring.
Here's the setup.
Here's the setup.
- Has thanked: 20908 times
- Been thanked: 10565 times
Nice captures James, they came out well. The sun looks pretty high in the sky at the time.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Awesome!
Marios S.Ioannou
Sketcher/Visual Observer
- rigel123
- Has thanked: 8628 times
- Been thanked: 8864 times
Very nice! You really got some nice details in those proms.
Thanks everyone. I really had fun. I like imaging when I have the time to stack and process all the files. It takes a bit more time than visual does. And Mark the Sun was quite high in the sky at the time. I observed a bit longer and later on Saturday and it was even more so. It would seem really high to you since I am south of you on the globe. Think, Rainer and Eric probably see it at or close to the zenith!!
- Has thanked: 9779 times
- Been thanked: 5813 times
Hi James,
Well done
Well done
Thanks Rainer!
- Has thanked: 1640 times
- Been thanked: 878 times
Nice images! I really like the proms. Temp in the mid 70s? Man that must be nice. I attempted to sketch at 630 last night and the heat index was 97!!! I may need to switch to EAA and sit inside until the heat bubble goes away:)
torsinadoc wrote: ↑Mon Jun 20, 2022 3:17 pm Nice images! I really like the proms. Temp in the mid 70s? Man that must be nice. I attempted to sketch at 630 last night and the heat index was 97!!! I may need to switch to EAA and sit inside until the heat bubble goes away:)
Wowsers, you are hot! Where are you located? Mid week we are forecast to heat back up.
Thanks for the compliments. I really liked the proms too. For some reason I seem to do better on proms than I do the disc.
NW Arkansas. It is unusually hot for JuneDeepSolar64 wrote: ↑Mon Jun 20, 2022 4:38 pmtorsinadoc wrote: ↑Mon Jun 20, 2022 3:17 pm Nice images! I really like the proms. Temp in the mid 70s? Man that must be nice. I attempted to sketch at 630 last night and the heat index was 97!!! I may need to switch to EAA and sit inside until the heat bubble goes away:)
- Ibbo
- Has thanked: 2451 times
- Been thanked: 1662 times
- Ibbo
- Has thanked: 9369 times
- Been thanked: 6194 times
Great job, James, very glad you are imaging again. Continue doing it and you will get better and better...
Thanks everyone. I need to image while I can. It's much easier to to in the warm summer months than in the cold of winter. And yes, practice should see improvement.
It's been a bit hotter here than typical though the last couple of days have been nice.
- Has thanked: 723 times
- Been thanked: 667 times
My favourites are the prom silhouettes and the WL (esp as those are the types of imaging I struggle w the most). Btw the 2nd image colouring reminded me of the Ukraine flag!
Thanks Vinyard. I was really satisfied with the prominence ones too. And hey, the Sun shines over the Ukraine ! Just ask Valery.
- Has thanked: 8587 times
- Been thanked: 8322 times
Great results, James.
- Has thanked: 2496 times
- Been thanked: 4917 times
Thanks Stu and Maurits. That means something because you two are accomplished imagers. I’ll keep moving on and forward.
- Has thanked: 6333 times
- Been thanked: 7378 times
Thanks Arne.
