The position of this filament was near ideal this morning. The seeing was typical (bad) but I've learned to have faith in the processing to produce some good results. I used an LS80 with an ASI1600 for a full disk and a Stellarview 127 and Quark for high res views with the ASI1600 under various ROI settings.
In the afternoon, I switched to a double stacked LS152 to produce a better tonal balance between the filament and the disk compared to the single stack arrangement in the morning. Notice that in some images the limb shows right through the filament (single stack) and doesn't show in the double stack image.
To see what the filament looked like on June 21, see
viewtopic.php?t=36735
Lou
The big filament continues on June 22
- Been thanked: 1735 times
- Been thanked: 1624 times
Re: The big filament continues on June 22
Great detail in those images Lou - well done. Regards John W.
- Has thanked: 20813 times
- Been thanked: 10481 times
Nice captures Lou, glad the sun is shining for you.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Good to see you're enjoying all this activity.
