6/14 and 6/19 sketch in continuum and Ha updated with 6-25
- Has thanked: 1640 times
- Been thanked: 878 times
Our weather has been unbearably hot. I am not able to view/image in the AM because of work. By the late afternoon the conditions are difficult. The last few days the heat index has been > 100F. This is atypical for my area. These are digital sketches. On 6-19 I utilized a grid to overlay the disc which helped with orientation and made it easier to get the spot size closer to what I view in the eye piece. I used an iPad, apple pencil and procreate to sketch. PS to rotate image
6-14 11:31 UTC
Continuum:
ES 102, continuum, baader wedge and baader zoom
Seeing 3, transparency 2/5. It was hazy had a high layer of clouds
Procreate digital sketch, iPad
6-14-22 continuum sketch by Torsinadoc, on Flickr
6-19 10:27 PM UTC
Continuum
6-19-22 continuum sketch by Torsinadoc, on Flickr
Ha
Lunt 100 SS, B1800 and baader zoom
Transparency 3/5 and seeing 4/5
heat index 98F
6-19 Ha sketch prom by Torsinadoc, on Flickr
6-14 11:31 UTC
Continuum:
6-19 10:27 PM UTC
Continuum
Ha
heat index 98F
- Has thanked: 9074 times
- Been thanked: 5977 times
Re: 6/14 and 6/19 sketch in continuum and Ha
Love your sketches Alan ! The FD is almost photographic.
- Has thanked: 20240 times
- Been thanked: 10111 times
Lovely sketches there ALan, thanks for sharing!
Thanks. I am still working on technique but I'm gaining a better understanding of the software
- Oh, I get it now!
- Has thanked: 65 times
- Been thanked: 48 times
Interesting technique digital sketching. Result looks like a photograph, very nice!
How much time does it take to make a drawing?
Hans
Hans
Sundancer ii on TS 102mm f/11 or TS 80mm f/6
- Has thanked: 2406 times
- Been thanked: 4737 times
Thanks everyone
Hans
It depends on the complexity of the disc. I use layers focusing on scale and anatomy. The entire process from start to end that takes a few minutes for a relatively low activity disc or >30 minutes (viewing and drawing). My Ha drawings take more time. I added noise to my WL image because it adds a little texture to the disc.
I made several master files that I can open and add solar details. It took a while to make the masters so that saved front end time. I also tried several different pencil settings, brushes, etc and when I found ones that I liked I made notes so I can reuse them (I use different pencil/settings for WL umbra than penumbra, etc I turn on a grid At a low magnification I will outline the relative location and scale of each area. I use layers for the umbra, penumbra and faculae. I zoom in at higher magnification and spend time drawing each detail using the outline as border to keep spot scale correct. I no longer use the penumbra, umbra and faculae outlines and only the original low magnification outline. Prior to adding the general outline I was off in scale and disc location for each area. I like layers because I may mess up and it is easier to fix without erasing other structures. Once I have double checked each area and adjusted (add blur or use blending tool) I turn off grid and flatten image. Since I sketch with manual Alt/Az mount I need to rotate and horizontal flip my image (PS).
I am spending time to try and improve my observational skills. I am finding that I am getting better at noticing subtle details in Ha and WL.
- Oh, I get it now!
Thank you very much for your detailled explanation on how to make the sketches!
From making sketches of Deep Sky objects in the past I know that one can see more details when one makes sketches, compared to "just looking".
My drawing skills were not so great however, so I stopped drawing.
Maybe good idea for me to start making sketches again during solar observation to notice more subtle details.
Hans
Hans
- rigel123
- Has thanked: 8189 times
- Been thanked: 8424 times
That really is fascinating!
I wouldn't consider my skills all that great. I can barely draw a stick figure but I still enjoy the process and find it rewarding.SolarHans wrote: ↑Sat Jun 25, 2022 10:14 am Thank you very much for your detailled explanation on how to make the sketches!
Hans
Re: 6/14 and 6/19 sketch in continuum and Ha updated with 6-25
Today's conditions were finally tolerable. It was in the low 80s with a slight breeze.
Equipment:
Celestron 150/1200 achromat + baader wedge, continuum filter- baader zoom. I should have used my binoviewers but my observing buddy (Franklin the dog) was being "needy".
Transparency was average, seeing was 3-4/5
Image is not rotated or flipped. N-S is 62.1 (from tilting sun) and west is up.
AR 3038
6-25_3038 sketch by Torsinadoc, on Flickr
AR 3040
6-25 206utc AR 3040 sketch by Torsinadoc, on Flickr
Equipment:
AR 3038
AR 3040
Nice additions ALan!
Amazing prominences sketches !
- nicspenceryork
- Has thanked: 5778 times
- Been thanked: 1236 times
Gorgeous sketches and really interesting to see how you create it.
Nic
Nic
- Has thanked: 17521 times
- Been thanked: 8763 times
These are absolutely terrific and thanks for the info on how you do it. It is great to see more sketching on the forum
- Has thanked: 17458 times
- Been thanked: 16553 times
These are awesome!! Sketching, whether by pencil or digital is a superior way to document the Sun by visual observation. Certainly better than the description method I use. I never would have realized that digital sketching could rival sketching with actual pencil and paper.
I don't know how I missed these.
Thanks everyone.DeepSolar64 wrote: ↑Tue Jun 28, 2022 4:53 am These are awesome!! Sketching, whether by pencil or digital is a superior way to document the Sun by visual observation. Certainly better than the description method I use. I never would have realized that digital sketching could rival sketching with actual pencil and paper.
I tried both pencil and digital. I found digital allowed easier storage with my digital images. It is nice to have everything in one place. I would NOT discount your eloquent ability to describe what you see in the eyepiece. I lack that skill.
Thanks for the compliment. I have plenty of practice on descriptions.
