ISS Solar Transit 2022.06.22
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
About 5 days ago, it seemed the ISS would transit over my office building. Obviously, an ideal scenario. Unfortunately, there was probably an orbital adjustment and the center line of the transit moved a 40 minute drive away. Irked about it, I gave up, but this morning I said “Nay! I shall not surrender! I shall capture this!”.
Armed with a 2.5 hour leave of absence from work, I set off and drove to a field to set up. Transit lasted 0.54 seconds at 13:19:46 and it appeared on time, albeit it was not a precise center crossing, despite me setting up 200 feet from the supposed spot of a center transit. Red spot is where I was situated, dotted black line was the supposed center path.
Lessons learned for next attempt:
1. Increase gain to drop capture to say below 3ms to “freeze” the ISS
2. Switch to 8 bit to capture more frames with the ISS transiting
3. Get a camera with a faster frame rate to capture even more frames
4. Ignore critical sampling if necessary and image at a shorter focal length to use different camera (I used the 183MM) and still get full disk
I am quite happy with the result and will be better prepared for future transits. I have to say, my heart was racing and I started the capture run 20 seconds before the transit, watching my laptop monitor like a hawk. I was screaming with excitement as I saw the ISS on my screen and KNEW that I captured it!
- 1F0FEFE7-94CC-4612-9594-58ED2099612A.jpeg (49.1 KiB) Viewed 1527 times
- 5618FC0C-04F1-4472-8824-F1A5F0D2C021.jpeg (436.73 KiB) Viewed 1527 times
- DEF590BC-E943-421E-94D2-D9CA69A1D368.jpeg (3.79 MiB) Viewed 1527 times
- CC836D47-38E9-44FF-9C76-8CE7F3659181.jpeg (3.7 MiB) Viewed 1527 times
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 2407 times
- Been thanked: 4737 times
- Has thanked: 9082 times
- Been thanked: 5977 times
- Has thanked: 9243 times
- Been thanked: 5504 times
Re: ISS Solar Transit 2022.06.22
Well done
- rigel123
- Has thanked: 8189 times
- Been thanked: 8425 times
Great catch!
- Has thanked: 17533 times
- Been thanked: 8763 times
Wow!! what a fabulous capture, well done I know exactly the feeling you felt
- nicosolcy
And the obligatory animated gif...
- ISS Transit Single Images GIF Small.gif (4.72 MiB) Viewed 1491 times
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 6161 times
- Been thanked: 7097 times
Great result Nick and thanks for sharing your learning-points as well!
Arne
Arne
- Has thanked: 20240 times
- Been thanked: 10116 times
That's pretty darn impressive! ISS transits are always a learning curve for me too.
- Ibbo
- Has thanked: 2415 times
- Been thanked: 1641 times
- Has thanked: 8355 times
- Been thanked: 8103 times
Nicely done. I’ve done this only once and I know exactly how you felt when you captured the transit.
- Lagonda
- Oh, I get it now!
- Has thanked: 57 times
- Been thanked: 156 times
I was using 0.449 ms to get clear ISS on solar surface when ISS was real close (521km away from me). I had 3m of focal length. I put the image here so you don't have to look it up. I hope you don't mind. Longer the focal length (bigger image of ISS) the shorter exposure you must have to grab it steady. I hope this will help you in future ISS imaging.
12_56_20_Sun_2021_08_07_f3952ar6cr by Alan Jadanic, on Flickr
- nicosolcy
Thanks All!
@ Lagonda: great shot! Will keep it in mind re exposure time. I will actually practice at various exposures and gain to find how much I can push gain before noise becomes a serious issue.
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 17458 times
- Been thanked: 16562 times
Determination pays off!!
- Has thanked: 230 times
- Been thanked: 176 times
