FDs in Ha and CaK 25th June 2022
- Has thanked: 8558 times
- Been thanked: 8288 times
Just a couple of disks from this morning.
I stopped down my 125 Tecnosky to 60 mm following a discussion with Mark for the B1800 Lunt CaK module. I had to remove the internal Omega filter from the B1800 module because the image was really unevenly illuminated. A bit more experimentation required to optimise.
20220625_CaK_FD_Mono by Stuart Green, on Flickr
20220625_CaK_FD_colour by Stuart Green, on Flickr
Ha FD using my Lunt 60
20220625_Ha_FD_Mono by Stuart Green, on Flickr
20220625_Ha_FD_colour by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 20803 times
- Been thanked: 10478 times
Re: FDs in Ha and CaK 25th June 2022
Nice disks there Stu, strange how illumination was uneven.
Hi Mark,
I think it’s the position/angle of the internal Omega filter. My guess is the higher focal ratio makes the setup more sensitive to angular misalignment if the filters are not exactly normal to the light cone. The Omega is only held in place with PTFE tape on the threads to make it fit.
Something to ‘fettle’.
- rigel123
- Has thanked: 8573 times
- Been thanked: 8806 times
Excellent disks Stu!
- Has thanked: 6296 times
- Been thanked: 7321 times
Many thanks, Warren, Arne and Alexandra.
- Has thanked: 9313 times
- Been thanked: 6153 times
Lovely views of the sun from the UK, Stu. Very windy here, now I understand some of the challenges...
- Has thanked: 286 times
- Been thanked: 399 times
Nice images Stu
Just a tip for the Omega filters, they fit perfectly into the 1.25 plastic moon filter fittings that are supplied with scopes like cheap Celestrons.
You may need to protect the plastic though.
- moon filter.jpg (17.89 KiB) Viewed 300 times
Many thanks, Franco I hope you’re enjoying your vacation
Thanks for the tip, Rod.
