Weds 22 June - HA & WL
- Has thanked: 689 times
- Been thanked: 640 times
Finally got round to processing data gathered that morning.
The HA is the usual kit (TV76, SF50, L3 filter, 178MMcool & 290MM+2.5x PM). The WL is still the ETX125 w Baader ND5 film, except this time I had received a Wegat back for the ETX125. What a wonderful modification that transforms the way that scope can be used!
I'm also trialling Astrobin as I've noticed a few forum'ers use it to store images in higher image size than jpgs?
- Sun_111028_220622_ZWO ASI224MC_Gain=0(off)_Exposure=.7ms_WL_LP_bin2_5_qe3_ap2472_imppg(220317WL)_gimp_wm.png (1.15 MiB) Viewed 409 times
- Sun_105325_220622_ZWO ASI290MM_Gain=110(off)_Exposure=2.9ms_HA_25PMbin2_3_qe3_ap954_imppg(220310)_gimp.jpg (130.91 KiB) Viewed 409 times
- Sun_104816_220622_ZWO ASI290MM_Gain=110(off)_Exposure=2.9ms_HA_25PMbin2_25_qe3_ap1351_imppg(220201)_gimp.jpg (55.15 KiB) Viewed 409 times
- Sun_104631_220622_ZWO ASI290MM_Gain=110(off)_Exposure=2.9ms_HA_25PMbin2_10_qe3_ap1222_imppg(220201)_gimp.jpg (120.82 KiB) Viewed 409 times
- Sun_105010_220622_ZWO ASI290MM_Gain=110(off)_Exposure=2.9ms_HA_25PMbin2_10_qe3_ap1072_imppg(220201)_gimp.jpg (124.16 KiB) Viewed 409 times
- Sun_104025_220622_ZWO ASI178MM-Cool_Gain=233(off)_Exposure=.8ms_HA_FD_10_qe3_ap2370_imppg(211122wd)_gimp.jpg (1.05 MiB) Viewed 409 times
- Has thanked: 20424 times
- Been thanked: 10242 times
Re: Weds 22 June - HA & WL
You got a nice set of images there Vin!
- Has thanked: 9143 times
- Been thanked: 6024 times
- Been thanked: 4340 times
Well done Vin
All of the images are very sharp!
Thanks Mark, Franco & Brian - that's v kind. Yes I was quite happy with what popped out, although I can also see the ways they can be improved. Practice, practice, practice
Btw the Wegat visual back just transforms the ETX125 - it even allows for BV'ing natively w/o any barlows or GPCs. I just had a short visual WL stint w the ND5 film, and the entire solar disc fits into the FOV w 25mm EPs used natively and its such an easier form factor to handle than a long refractor.
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 16689 times
Vin,
You got the big NW filament very well too!!
- Has thanked: 17648 times
- Been thanked: 8787 times
- Been thanked: 4904 times
Vin:
Beautiful clean and crisp images.
Best regards and thanks for sharing.
I have the Macs up and running and have been learning how to navigate and use them. I have now backed up a third copy of the last three years of solar work using it. I have yet to use it for imaging due to the weather. The last three days have been largely overcast. It's coming though. I look forward to trying out ASTRO IIDC and the Point Grey Grasshopper.
