something silly in cak
- Has thanked: 57 times
- Been thanked: 1204 times
i used a mx9916 night vision tube to look at sun in cak
shot with s8
yu can see spot with some lighter areas
lot better visually
shot with s8
lot better visually
- Has thanked: 20813 times
- Been thanked: 10484 times
Re: something silly in cak
I've thought this is something that might work. Interesting result John.
- Been thanked: 4427 times
Cool image form your experiment
- Has thanked: 17849 times
- Been thanked: 16992 times
Nice idea John!! That might help old folks like me actually see CaK!!
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Not silly at all. It's a viable way to do visual CaK.
- Has thanked: 716 times
- Been thanked: 659 times
Oh wow that's really interesting. (And given how much NV tubes cost, well done for being that brave with this experiment!). So did you just put the NV tube on the end of the CaK filter (with no other energy rejection in front of it)? And was this prime focus or afocally?
Primary focus
Used omega filter
But could use lunt also
Don't turn on until all in place or bye bye tube
This is an old gen2 s25 input
Do not use gen3
So price risk was much lower
I'm not going to use a 2k+ gene tube for this
Used omega filter
Do not use gen3
keep in mind there is a cheaper way that works almost as well (a bit lower resolution)
that is to use a UV to visible light converter eyepiece
I never knew there was a such thing! Are they expensive? This would possibly be a good way to visual CaK!
DUH yes
I invented it
I won Stellafane first prize in 2017
there is thread in MOD forum article i wrote
you can make one
20 bucks
I invented it
you can make one
20 bucks
I admire and appreciate such creativity.
- Been thanked: 4980 times
John:
Remembered Stellafane.
Thanks for sharing your work.
Best regards.
Best regards.
