June 27 2022 AR3040 and prom Ha
- Has thanked: 1262 times
- Been thanked: 1057 times
Hi all,
today I tried to get lucky with the following: C11(Aries D-ERF) + Quark + Player One 432 camera (9um) without a focal reducer, relying on very promising seeing forecast 1"...
I checked with the Solar Spreadsheet file, it shows critical sampling at f/42 and I obtained f/40 by fact, 0.17"/pix. Images looked oversampled and best record moments with about 1" seeing were not enough for such a scale. Or both.
I still decided to share couple of files, AR3040 with a pretty small spot and prom on SE limb.
Leo
Leo
- Sun 20220627 0655_8 2 AIPs.jpg (607.61 KiB) Viewed 555 times
- Sun 20220627-0719_0 AI2OPs .jpg (850.24 KiB) Viewed 555 times
- Has thanked: 1640 times
- Been thanked: 878 times
- Been thanked: 10248 times
Re: June 27 2022 AR3040 and prom Ha
They still look good Leo! Viewing them less than full size in the forum thread compensates for any apparent oversampling.
- Has thanked: 9145 times
- Been thanked: 6026 times
- rigel123
- Has thanked: 8316 times
- Been thanked: 8544 times
They look great!
- Been thanked: 8793 times
Wow!! if only I could match this did you use a 4x telecentric to get the f40?
- Petrus
- Has thanked: 1496 times
- Been thanked: 684 times
I have no words... Wowzwers!
Incredible capture Leo.
~ Petrus ~
Flickr
Flickr
- Has thanked: 2978 times
- Been thanked: 2082 times
Very nice results Leo, SCT + Quark + Apollo Max == dreamteam.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 8418 times
- Been thanked: 8165 times
Very nice indeed. Congratulations on SPoD.
- Has thanked: 6181 times
- Been thanked: 7142 times
Great results, Leo!
Congrats on a well deserved SPOD!
Arne
Arne
- Been thanked: 4904 times
OMG, SPOD! Many thanks to all of you for kind comments, very appreciated!
Mark, I know you're very attentive to have an optimal sampling of every setup, it's correct indeed. I tested the limit.
Alexandra, although I use the standard Quark 4.2x, I was surprised when took 3 pix position on the limb to measure the actual focal ratio and got f/40, less than nominal. Maybe it is due the mirror position. The distance between rear Quark filter and the chip was about 65mm, the robo focuser added more 90mm space between tube and Quark.
Dennis, the only true that SCT + Quark + Apollo Max is very demanding of the seeing!
thanks for looking
Leo
thanks for looking
Leo
- Been thanked: 2713 times
Splendid Leo !
The 9 micron pixel is a perfect match for your setup. Well done !
- Has thanked: 17581 times
- Been thanked: 16697 times
Congrats on the SPOD!!
Many thanks, guys!
Exactly, Christian, that was the first reason to take 432 camera with 9um pixel for C11+Quark!
regards
Leo
regards
Leo
