June 30 2022. Attempt at imaging :-(
- Has thanked: 17862 times
- Been thanked: 17006 times
Session time is from about 15:00 until 16:30 UTC with most of it sitting under an almost overcast cloud deck. I never really got a clearing and tried to image through clouds. It seemed that when adjusting the exposure in ASTRO IIDC to the PGR Grasshopper I was either too bright or too dim. I spent a considerable amount of time fiddling with the exposure and brightness plus the clouds varied the exposure constantly. I don't think I ever really got it right. Tuning and focusing was an issue too. I had quite a bit of problems seeing enough detail on the monitor to tune or focus on! I was quite dismayed by the end of the session. I had intended to image white light too which should have been a bit easier but clouds completely had me by that point. The temperature was 80F ( 26.6C ) and humid at session's end.
I used the SMII60 in SS for today's imaging attempt.
Below is today's BEST image :-/
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Re: June 30 2022. Attempt at imaging :-(
Lovely picture, nice style of processing in my opinion. I like the halo.
Frustrating not to get the surface details I guess!
Good luck
Robert
Good luck
Robert
The processing might have been the bright point but the lack of surface detail was very frustrating.
Thanks.
- rigel123
- Has thanked: 8589 times
- Been thanked: 8823 times
Lovely, artistic image of the sun James! I think the clouds really sapped the details out of your disk but gave you that lovely halo.
I am sure the clouds had a lot to do with my bland disc but I still wonder how much of it was my lack of skill.
And yes the clouds gave me that wonderful halo that I added color to. It was actually more extensive if I would have left the area around the sun brighter.
The next week doesn’t look too good for either visual observing or imaging. Clouds and thunderstorms are numerous in the forecast.
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Right! Empty carton box to put laptop in so that you have some shade to see contrast on the monitor, or go hardcore and do the same with a blanket over your head and laptop!
The clouds give a nice twist to the final image!
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
I usually use a plastic storage bin to place the laptop in to shield it from the Sun but sometimes I place it on a bench against the small storage shed I store my Losmandy mount since the shed provides ample shade for the laptop in the late AM hours.
The cloud produced halo did add a nice touch to the image. It added an artistic touch to an otherwise bland image.
- Has thanked: 8559 times
- Been thanked: 8297 times
10/10 for persistence, James. Sometimes you just have to know when you’re being defeated by the conditions. We’ve all been there, I’m sure. I know I have!
- Been thanked: 8907 times
I admire your persistence James, I would have given up straight away However, you do have a lovely shot for the effort. I think you might have a more relaxing time if you just wait for a very clear day when you can spend time fighting the imaging and not doing double battle with clouds as well.
You get the bravery badge though
- Been thanked: 4981 times
James:
Hard when haze or clouds do not help.
Persistence is the only way to deal with these conditions.
Best regards.
Best regards.
Thanks everyone. Frustrating it was. I probably should have done just a white- light visual. I certainly would have enjoyed it more.
- Has thanked: 20828 times
- Been thanked: 10502 times
You're on the learning curve so don't be dismayed James. It's a good start and we all had to start somewhere, persistence will pay off.
Thanks for the encouragement, Mark. I’ll keep at it.
