Best solar image to date
From 19/6/22, Lichfield, UK
Daystar Quark
1ms exposures
25 sec videos
123fps
ImPPG
Photoshop
PlayerOne SolarMax camera
Any suggestions welcome!
Andy
Daystar Quark
1ms exposures
25 sec videos
123fps
ImPPG
Photoshop
Andy
- 2022-06-19-0744_4-U-G-Sun_AS_P15_lapl2_ap1230_Drizzle30_AS_190622 ImPPG & PS Greyscale DeNoise 010722.jpg (1.18 MiB) Viewed 528 times
- 2022-06-19-0744_4-U-G-Sun_AS_P15_lapl2_ap1230_Drizzle30_AS_190622 ImPPG & PS Colourised DeNoise 010722.jpg (1.46 MiB) Viewed 528 times
- Has thanked: 286 times
- Been thanked: 399 times
Re: Best solar image to date
Hi Andy
That's an awesome image, loads of detail and very dramatic.
What scope did you use?
My only suggestion is for cropping the disk, is to use Corono a freeware program for creating coronagraph type images.
First open your image in Corono and create an image that blacks out the proms by selecting three points along the limb of the sun, Corono then creates the curve for you and blacks out the proms, save the image.
Then open the Corono image in Photoshop and now use the magic wand to crop the suns surface and paste it onto your original brightened prom image.
This will give you a sharp edge so it may need a bit of playing in ImPPG with the original curves to get the two to blend nicely.
There are probably other ways of doing this in Photoshop but I can't find them.
I had a crude go with your image below so the original image is not in the right place just to show how it would work.
You may not like it but its all good fun experimenting.
Rod
Rod
- 2022-06-19-0744_4-U-G-Sun_AS_P15_lapl2_ap1230_Drizzle30_AS_190622 ImPPG & PS Greyscale DeNoise 010722 crop corono.jpg (1.21 MiB) Viewed 518 times
Hi Rod,
Thanks for that. I have never heard of Corono. Perfect! I wondered how you folks sorted out the edge!
Andy
Andy
Hi Rod, I have had a look but cannot find the Corono ml software you mention. Can I ask for a URL?
Andy
Andy
Hi Andy
I have sent you an email
Yep sadly Corono seems to have disappeared but I am just messaging the writers to see if it is possible to get it somewhere.
Cheers Rod
Cheers Rod
- Has thanked: 3058 times
- Been thanked: 2161 times
Awesome image.
Why only 1ms of exposure time when you can have ~8ms with the cam not loosing any fps?
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Been thanked: 10489 times
That came out well Andrew, nice shot there!
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Here is the link to Corono software
http://sweiller.free.fr/Softwares/Corono/corono.html
Clare & Peter
- Has thanked: 17853 times
- Been thanked: 16996 times
That’s certainly an image to be proud of! Nice detail!!
I’ll check out Corono too. I have never heard of it.
Thanks for the link Clare and Peter
Could I find it on google
And couldn't get a message to Sylvain Weiller because of Microsoft messaging problems.
Then when I opened your link I found I already had it in my bookmarks
Cheers Rod
Cheers Rod
Thanks Rod. I'll give this a try.
- Been thanked: 4980 times
Andrew:
Very nice images.
BTW, have used the Corono software since long and works really nice.
Best regards.
Very nice images.
Best regards.
I just downloaded Corono. :-)
