2.7.2022 First whitelight images, closeups, different filters
- Has thanked: 3058 times
- Been thanked: 2161 times
Hi there,
i wanted to try some whitelight imaging with the C9.25 and got great advice about it from Christian (thanks again). Seeing was mediocre, not much on the solar disk for h-alpha, so it was a good day to try sth new.
First i used a Baader 10nm OIII filter (image description). Later on i thought "why not trying that old Baader Venus U filter you got years ago, collecting dust?"
Quite interesting first results with both filters. Despite scts are not well corrected in blue, i somehow liked the results the uv filter gave.
I still have to get used to the editing of WL, but so far i am pleased of the outcome.
All images are a "stack" of best 1-2 images (still playing with that). Telescope at F/40.
Thanks for looking.
Thanks for looking.
- 0507_8_Baader_OIII.png (1.21 MiB) Viewed 438 times
- 0539_4_.png (1.41 MiB) Viewed 439 times
- 0602_9_.png (1.48 MiB) Viewed 443 times
- 0552_3_2.png (1.48 MiB) Viewed 444 times
- setup.jpg (1.39 MiB) Viewed 479 times
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- p1taylor
- Been thanked: 219 times
Re: 2.7.2022 First whitelight images, closeups, different filters
Hi Dennis really good images.
peter
peter
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Those came out great!
- Been thanked: 10489 times
Good results there Dennis!
Thanks Peter, Warren and Mark.
Didnt know WL-imaging can be so much fun. I will try to image at native focallength next time, but it will be too bright for the OIII.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 17853 times
- Been thanked: 16996 times
Dennis,
Nice work experimenting with different filters on the photosphere. Some of the images have almost a CaK look. Maybe you should add a wideband CaK filter like the Baader K-Line filter or Antlia CaK wedge. Though you might get a little CaK details in the lowermost Chromosphere it will be the photosphere you will mostly see and the short wavelength will foster great resolution if you have good seeing. A 430nm Gband filter is a plus too. I have one and need to use it but I rarely have seeing good enough.
- Been thanked: 4980 times
Dennis:
Very good images, good experimenting.
Best regards.
Best regards.
Thanks James,DeepSolar64 wrote: ↑Sun Jul 03, 2022 1:36 am Dennis,
the funny thing is that i used to have a Baader K-Line Filter ages ago, sold it
Now im thinking indeed of getting a very narrowband K-line filter like the Antlia.
Im interested in a K-Line filter because it still shows the granulation, so i wont go for a real CaK Filter.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
I’ll probably get an Antlia K-line filter eventually. They show the faculae across the disc well. And they are much cheaper than the ultra narrowband Lunt CaK wedge.
Thanks Alexandra, your blogs and public information on how to do solar imaging helped me a lot.
Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6305 times
- Been thanked: 7324 times
Good high-res results, Dennis!
Thanks for sharing,
Arne
Thanks for sharing,
Arne
