Hi Everyone.
Part of my June 23 spectroheliography session was devoted to experimenting with a barlow on the telescope (C4 NexStar with Celestron barlow) for a more magnified image scale. At first, I didn't think much of the results because of severe vignetting with the barlow. On closer inspection, though, the imaging didn't turn out too badly with some cropping. Instead of posting a single image, I've decided to post an animated series of images taken at various wavelengths, stepping from the red wing to blue through the H alpha line. That's a result of improvements I've made to speed up and automate my image processing.
Here is the area of the solar disk I imaged (roughly bounded by the red box).
Here is the animation.
Peter
23June2022: AR13038 - Spectral sweep through H alpha.
- Has thanked: 20240 times
- Been thanked: 10115 times
Re: 23June2022: AR13038 - Spectral sweep through H alpha.
That is pretty impressive Peter!
- Has thanked: 17526 times
- Been thanked: 8763 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Thanks for your comments, Mark and Alexandra.
There's actually some interesting information hidden in the animations. If you look at features in the red and blue wings of the H alpha line (symmetrically spaced around line centre) they are actually quite different. This is because of their motions and the corresponding Doppler shifts in their absorption line centres. Here is a montage of images in the red wing, line centre and blue wing of H alpha.
The interesting comparison is between the top and bottom images. I thought I would make this more obvious by posting (yet another) animation! This is simply an animation involving the two red / blue wing images and a blending "morph" between them.
The start of the animation loop is in the red wing and a bounding box appears there. Interesting stuff happens inside the box where you can see features receding from us (at 137 km/s) at the beginning of the loop and then approaching us (at 137 km/s) by the end of the loop. You can see that the fibrils (roughly oriented East-West ie. left - right) become more apparent in the blue wing, indicating they have a velocity component away from the solar surface. There are also features which start with a large motion downward and then nearly disappear in the blue wing.
The spectrum associated with this region is also pretty complex as a consequence of these motions. At some point I'll post a sample.
Peter
Peter
- Has thanked: 8355 times
- Been thanked: 8103 times
Excellent, Peter. Very impressive and informative.
- Has thanked: 57 times
- Been thanked: 1173 times
