I still have to fix the tilt of the camera - I partially fixed it but it is too hot to stay under a blanket for too long!
Played in single stack mode, best 250 out of 1,000 frames with the Lunt 50mm Ha and Player One IMX178MM, plus a Barlow set at about 1.3x magnification. Once I get the tilt right, time to slap on the DS module!
So much to still work on to do this (I recall going through the same process when I had my 60mm), but I'll get there!
Sol FD Ha 2022.07.03
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
- Sol 2022.07.03 Ha.jpg (1023.69 KiB) Viewed 303 times
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Been thanked: 10247 times
Re: Sol FD Ha 2022.07.03
That came out well Nick!
- nicosolcy
Mark,
Thank you for the kind words but this needs a ton of work! I tell you, Cyprus is NOT the place to be when you want to adjust camera tilt in early July! I'll get there though, it will take a few trial runs to get everything going.
Today was more of a systems check. I updated everything on a Mac (Intel based) where I have a dual install of Windows and Mac OS and at least everything runs like a charm.
Also, given the image scale, I used a Barlow component placed at about 1.3x which pushes me marginally into oversampling territory. I will try removing it and using drizzle when stacking to compensate, plus the super resolution function in Pixelmator Pro to see if I am "covered".
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Been thanked: 8791 times
That's an absolute beauty, well done for enduring the boiling to get it
- nicosolcy
Thanks Alexandra!
I will stupidly try today (41°C) to finalize the tilt adjustment and take it from there
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- Has thanked: 6181 times
- Been thanked: 7142 times
This came out very nice, Nick!
A little bit of uneven sharpness... is this caused by the tilting you are referring to?
This will be a very nice setup once you get everything tuned!
Arne
Arne
- nicosolcy
Hi Arne,
Indeed, I have to play some more with the tilt adjusting mechanism. It was 41C yesterday afternoon so self survival was preferable to playing with the scope
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
