here is regular filter Ha to show what I'm trying to lock on
hbeta
HeD3
my first hbeta with open slit
- Has thanked: 57 times
- Been thanked: 1189 times
- Been thanked: 8791 times
- Has thanked: 259 times
- Been thanked: 237 times
Re: my first hbeta with open slit
this is not bad at all :
Could you send me a shematic of your spectroscope ? I think i could look at it and help you to improve it ( if you are interested of course .)
its classic design
60mm X 700mm scope
50mm X 200mm collimator
1200lpmm grating.
50mm X 300mm imaging scope
and..
slit is reworked surplus shed
60mm X 700mm scope
1200lpmm grating.
and..
hmmmm ,
i wouldnt use a 50mm diam 300 mm imaging lens : it means you have a factor k= 1.5x ; that means the final image will be bigger but fainter (less light) . That could explain loss of contrast and loss of sharpness a bit. and it'll limit the range of eyepieces you can use if you want to watch live.
f/D=12 isnt bad what camera are you using? have you calculated your sampling rate ? I can do it for you if you give me the camera brand model (i'll will find the pixel size). I wonder if you're not oversampling your prominences image ..
and with some thinking i would even say that a pair of binoculars objectives lens (30 mm diam 135mm f) could be much better : you might gain more light. What size grating do you have ?
I can u a shorter 50mmX200MM F4 imaging scope
I thought bigger was better
i use either zwo asi290mm or asi178mm
grating is 1200lpmm 35mmX35mm
