5.7.2022 AR3046 / 51 closeups in WL
Dennis
Has thanked: 3053 times
Been thanked: 2154 times
Post by Dennis »
Something of the latest WL imaging tests:
With the help of 2 stacked 3x tv barlows I tried to push the C9 towards F/60. Since its in the uv-spectrum at ~ 380nm (Baader U filter) the resolution still has some breathing room. Seeing was good/average, with lucky imaging i managed some shots that showed quite some detail.
I know, scts are not made for uv, but nevertheless its fun and im curious about doing this with good / very good seeing conditions.
Is it just me or does it look like parts of the granules are falling into the sunspot on the north/west site?
Stacks of best 10 of 1600 images each (109 fps).
Thanks for looking
Dennis
(Edit: replaced the overdone ones with a more moderate editing style)
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Has thanked: 20757 times
Been thanked: 10444 times
Re: 5.7.2022 AR3046 / 51 closeups in WL
Interesting results Dennis, what does an unprocessed image look like?
Dennis
Post by Dennis »
marktownley wrote: Tue Jul 05, 2022 9:17 pm Interesting results Dennis, what does an unprocessed image look like?
Thanks Mark, it looks like this:
Im still working on my processing with those images.. its totally different then my h-alpha.
Triband C9.25
Barlows:
-2x TMB 1.8x
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! I don't get anything half as good as that from my C11. I need to download that unprocessed image and practice my processing as I have no idea how you extracted that. I always knew my processing skills aren't good :shock:
:bow :bow :bow :hamster:
Dennis
Post by Dennis »
Montana wrote: Wed Jul 06, 2022 6:54 am Wow!! I don't get anything half as good as that from my C11. I need to download that unprocessed image and practice my processing as I have no idea how you extracted that. I always knew my processing skills aren't good :shock:
Hi Alexandra,
then better use the tif file, PW: Solar:
https://easyupload.io/v2x1yg
Regards Dennis
Triband C9.25
Barlows:
-2x TMB 1.8x
torsinadoc
Has thanked: 1640 times
Been thanked: 878 times
Post by torsinadoc »
Excellent HR images
Dennis
Post by Dennis »
Actually i think i made a mistake.. i wanted to get F/60, but what i used was 2 stacked 3x barlows..
that would result in F/90, correct? That would be crazy.. how can this work..
The mount was definitive at its limit with keeping the sunspot in the center of the image.
Triband C9.25
Barlows:
-2x TMB 1.8x
Crazy trials are fun, but i'd back off the barlowing a bit for day to day use. Lack of definition in the penumbral fibrils in the raw file suggest seeing was around 1", much less than system resolution. All that glass is not good down in the blue either.
Dennis
Post by Dennis »
marktownley wrote: Wed Jul 06, 2022 8:06 pm Crazy trials are fun, but i'd back off the barlowing a bit for day to day use. Lack of definition in the penumbral fibrils in the raw file suggest seeing was around 1", much less than system resolution. All that glass is not good down in the blue either.
True, now that i hit the boundaries of the setup i will go back a bit for sure. But it seems this magnification works for days of very good seeing.
Im so curious to image the new active area thats coming around now. Bigger sunspots, more details..
I try to use barlows and not powermates for that reason. The good thing is that even that amount of glass didnt bring down the light flux too much. I still could image with using almost no gain.
Triband C9.25
Barlows:
-2x TMB 1.8x
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Here's my take Dennis.
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
It’s good to push the limits :)
Nice results.
Dennis
Post by Dennis »
marktownley wrote: Thu Jul 07, 2022 6:00 am Here's my take Dennis.
I like it Mark, looks very balanced.
Triband C9.25
Barlows:
-2x TMB 1.8x
Dennis
Post by Dennis »
My improved, less overdone version, but now from only the best image.. sadly with some dustspecks on the spot, but more moderate edited:
Triband C9.25
Barlows:
-2x TMB 1.8x
rigel123
Has thanked: 8547 times
Been thanked: 8781 times
Post by rigel123 »
Nice Dennis, this was my take, very similar to Marks.
Dennis
Post by Dennis »
rigel123 wrote: Thu Jul 07, 2022 5:52 pm Nice Dennis, this was my take, very similar to Marks.
Also nice, Warren. Smooth like marble :)
Looking forward for the next spot coming around.
Triband C9.25
Barlows:
-2x TMB 1.8x
