Improved H-alpha SHG high-resolution imaging from morning of 11 July
- Has thanked: 42 times
- Been thanked: 1485 times
With some hot sunny weather in London, we've been able to keep practicing and trying to improve our SHG imaging efforts. Versus the last run viewtopic.php?t=36970, we attempted to get a more even illumination of our SHG optics. This required taking out the scalpel and hot glue gun to do some foamboard surgery. For those who have followed our SHG efforts, our main instrument is conceptually like the SolEx http://www.astrosurf.com/solex/sol-ex-c ... on-en.html but built from foamboard and hot glue, rather than 3D-printed PETG.
When we originally built our device, it was designed to use a 3mm long Thorlabs slit. Since upgrading to a 12mm long lithographic slit, the small alignment errors of the collimator lens versus the camera lens were much more noticeable. We performed the surgery and inserted some small cardboard shims to correct the misalignment (by slightly raising the front of the camera lens and slightly raising the back of the collimator lens).
As a result, we were able to get much more even illumination across the long slit. The focus across the slit was also improved slightly but it was still difficult to bring the whole length into good focus at the same time. Below is a good image taken with a kind of "average focus" across as much of the solar disk as possible. The image is quite large (the video file was 3300 pixels wide) so best to see the image at full resolution by opening in a new tab.
I think there was a mount balancing problem (one I had never seen before) so a lot of images scanned in one direction I had to toss out. In the end, I found 26 images of good quality and told AS3! to stack the best 10. For comparison, here is an image from Arne Danielsen taken a few hours later on the same day with a Coronado 60mm: https://www.astrobin.com/full/5buv9r/
I played with the focus a bit and managed to improve the focus on the big feature in the top half (AR3053). Again there were mount problems so I could only find 19 good images to stack and asked AS3! to stack the best 5.
Unfortunately, I did not try to readjust the focus again to try to bring the bottom actively area into better focus (AR3055). Nevertheless, I made a 100% crop from the full disk image above and applied a bit more unsharp mask to bring out the details.
- hopskipson
- Has thanked: 404 times
- Been thanked: 191 times
Re: Improved H-alpha SHG high-resolution imaging from morning of 11 July
Wow those are some nice images! I’m just trying to figure out how to put the Sol’Ex together but images like these are an incentive to get it done.
- Has thanked: 883 times
- Been thanked: 548 times
Wow! Really interesting imaging thecnic.
- Has thanked: 17521 times
- Been thanked: 8763 times
these images get better and better, I am just blown away by the quality I take my hat off and salute you
Just to help people understand how the images were created, I also show a screenshot of the FireCapture and EqMod applications while in use. The image signal is in the fine lines of the curved H-alpha line. You can see that the left side shows sharper focus than the right side, demonstrating that it was difficult to achieve good focus across the whole solar disk. The brightness of the two sides is quite well balanced, however.
The exposure was set to 1ms (which is quite fast) and means that the fps was set by the USB traffic speed (which had to be set to no higher than 75% to avoid "lost frames"). The gain setting was used to control the brightness of the image and of course should be set to as low as feasible. The brightness of this image is about what it should be for optimal imaging: there are fine lines visible within the H-alpha spectral line but nothing in the line looks saturated. It does not matter if the data outside the spectral line is saturated.
Acquisition of an image involves the following steps: (1) move the Sun's image off the slit so the ROI window is dark by using the W-E buttons (in the case of scanning in RA; use the N-S buttons if scanning in DEC); (2) start acquisition ; (3) scan across the Solar disk using the W-E button; (4) watch the data signal appear and then disappear again and then halt the acquisition. If doing multiple scans, repeat the process (but it's important to stop and restart after each scan). If you are done with acquiring data, put the Sun's image back in the middle to slit so you don't lose the position.
I would suggest processing the first few scans right away in order to check things like scan speed, gain setting, and in particular the focus. If all the settings look good, I would recommend taking as many scans (back and worth) as possible in order to have some that will have "lucky imaging" and also due to the fact that inevitably there will be several where something went wrong. If you have enough good frames, you could try stacking but that's a more advanced process that isn't absolutely necessary.
To give an impression of what "good raw data" looks like (and also a typical fault), I attach here the reconstruction of a single SHG scan. In this example, the "geometry correction" is turned off so the image looks like a slightly rotated egg. The "transversalium correction" is also turned off so there are some fine horizontal lines visible. On the left side, there are obviously a large number of scans that somehow were not recorded (either a camera or computer error). Apart from resizing and turning into a jpg, there was not any additional processing done.
Here is an image from a single SHG scan, rather than a stack of 5, as shown above. Perhaps not surprisingly, the stack evens out some noise but I see that a few fine details are also lost, when looking at a very small scale.
I should mention that since this image is 1721 pixels wide, the average fps was 283, and the Y/X ratio was 0.948 (a slight overscan), the region spanned by this image took approximately 6.4 seconds to acquire (with each vertical line being acquired in 1ms).
- fulvio.mete
- Been thanked: 84 times
Excellent images, Douglas, sincere congratulations for this result!
Fulvio
Fulvio
- hopskipson
Thanks for the explanation of how you capture the images. I have been studying the Sol’Ex website and although it is informative the critical videos are all in French. Any insight into your set up and acquisition process would be very helpful. I have completed the construction and will be using a ST80 with 70 and 65 mm masks. I got an 82 mm 0.6 nd filter. The weather hasn’t cooperated to test it out yet but I was able to get get some images of the spectrum.
You set the exposure to 1 ms. At what rate did you scan the disk? I’m still learning this new technique, is it possible to see your set up?
I've posted this photo elsewhere but I'll put it here also. This is how the setup looked last summer, but it hasn't changed too much on the outside. I'll try to take a new picture next time.hopskipson wrote: ↑Mon Jul 18, 2022 3:27 am You set the exposure to 1 ms. At what rate did you scan the disk? I’m still learning this new technique, is it possible to see your set up?
The scan rate depends on the focal length and FPS. At 700mm FL, I use 14 or 15 time sidereal rate. That corresponds to around 290 fps. I actually require the very short exposure of 1ms or less because I am not using an ND filter. The reason for not needing any attenuation is the custom made slit I am using (lithographically patterned chrome on fused quartz) that is more robust than the standard Solex slit. The Shelyak slits are, I think, made of normal glass.
With the ND filter of 0.6, you will get a 4x reduction in light, which means you should probably target an exposure of 4ms. That will give you an fps of 250. If your telescope has a 400mm FL, the image projected on the slit will be 4/7 of mine so the distance travelled to scan will be less. So I'm guessing you could scan up to a rate of 20x if you wanted. You might want to scan slower (like 16x) and bring the fps down to something like 200.
It turns out that it's very helpful if your mount is quite accurately polar aligned. Then there will be very little drift, which can complicate centering the sun on the slit for long periods of time.
Another easy mistake is misorienting the SHG so there is a lot of "tilt" in the images. The easiest way to get the orientation right is to put the telescope in the "home" position -- i.e. pointing towards Polaris. Then orient the SHG so the the flat sides of the SHG are either exactly vertical (for scanning in RA) or exactly horizontal (for scanning in DEC). The choice of which direction to scan in depends a lot on the mount. Most will scan better in DEC so I would do that. The images will then all be rotated by 90 degrees. Just by visually adjusting the orientation, you can get the "tilt" down to 1 or 2 degrees. You can improve this during measurement by noting that the scan should begin and end at the same position on the slit. That will get the "tilt" down to around 0.5 degrees.
- hopskipson
Thank you again for the informative response! I guess I’ll try to search the archives for more details. Thanks again and good job with your set up.
- Has thanked: 20229 times
- Been thanked: 10111 times
Fascinating, with excellent results Douglas!
