Measurement of magnetic field of AR 3053 and 3055 through Zeeman effect
- fulvio.mete
- Been thanked: 84 times
The transit on the disk of two active regions of considerable extension allowed me yesterday morning to repeat once again the exciting (at least for me) experiment, for which I adopt a strict program, of a military type, under penalty of unsuccessful work, considering that the solar disk is visible from my house for no more than 1h and 15 min, in this period between 9 and 10.15 a.m. Then wake up at 7.30, preparation and control of the instrument, connection of cables to the PC and then the unpleasant positioning of the spectrograph on the Losmandy mount (which means keeping a weight of 15 kg perfectly still for the insertion of its Losmandy dovetail bar into the mount plate (for my age it is not a trifle). At the start of the management program a moment of panic: it did not respond, it was impossible to focus the spectrograph,then attempt to restart the PC, nothing: in the end, I remembered that the program was started only with a given USB port, and I solved it. In the meantime it was 9.30, and the clock ticked mercilessly. In the end I extracted 8 videos, in which the splitting of the iron line at 6173 Å was clearly visible.The dispersion of the spectra, with 4.65 micron of ,my DMK 51, was 0.01 A7pixel, R = 77000 (the seeing was not good,weather windy, focus not perfect).
This morning I calculated the magnetic field in Gauss of the two sunspots.
The procedure (in short) is as follows, using Valerie Desnoux's Visual Spec program:
1- I import the spectrum into the program, calibrating it in wavelength and flux
2- I measure the centers of the right and left cusps of the Iron line at 6173 A, make the difference in Å and divide the result by two
I then apply the following formula, where:
B is the magnetic field in gauss
λ is the wavelenght
g is the Landè factor (for Fe1 at 6173 is 2.5)
B = Δλ / 4.67 x 10^13 x λ^2 x g
In our case is:
1-For the 3053= Δλ = 0.216/2 =0.108
B = 0.108 x 10 ^13/ 444935733 = 2427.31 G
2- For the 3055: Δλ = 0.2089/2 =0.104
B = 0.104 x 10 ^13/ 444935733 = 2337.41 G
Probably the value of AR 3055 is underestimated due to its horizontal extension respect to the position of the slit.
This values are not too high for sunspots, but huge when compared with that of the earth (0.5 G).
The attached images show Solarscan on the Losmandy G11 mount, the two multipolar active Regions 3053 and 3055 (solar image Soho source) with the relative spectra , the images of the splitting of the iron line at 6173.34 Å due to the effect of the magnetic field generated by the spots, the spectral profiles of the two spectra, for the 3053 and 3055 with the center of the cusps in Å.
- Has thanked: 42 times
- Been thanked: 1485 times
Re: Measurement of magnetic field of AR 3053 and 3055 through Zeeman effect
Hi Fulvio, your lines are very sharp and the splitting is very clear. You mention polarising filters. Under what circumstances would linear and circular polarisers be used? Is it for different spectral lines with different angular momentum?
- fulvio.mete
Hi, Douglas: as I know Zeeman effect is most sensitive to circular polarization, so the measurements could be more precise.A friend of mine, solar physicist say up to 10%.In every case you need a spectropolarimeter, formed by a 1/4 wave retarder and a circular polarizer to place in front of the slit.The rotation of the retarder select the right or left polarization.Unfortunately the retarder is expensive, and , for now, i'll continue to use my system.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Beautiful work, Fulvio (in spite of your “rocky” start)!
The splitting of the Fe 6173 line is so sharp. You can clearly see the pi and both sigma components. In fact, the pi components in the two sunspots have different intensities relative to the sigma components which, I believe, gives you some information about the inclination of the magnetic field lines relative to the line of sight. What kind of grating and collimating lens do you use? Do you fit the triplet with line profiles or simply measure peak locations?
Your splitting is clear enough that I don’t believe a circular polarizer will make any difference to your measurements. The only additional information you’d collect with the circular polarizer in a polarimeter configuration is the polarity of the magnetic field (as well as discrimination against the pi component).
Peter
Peter
- fulvio.mete
Thanks for comment Peter:I've been using Solarscan (originally developed for spectroheliography in remote) exclusively for this job since some years, considering its perfomances. The grating is a 2400 g/mm holo grating in an adjustable cell: the collimator is a SW 80/600 ED lens in a Littrow design, and the telescope a Takahashi 60/355 Fluorite refractor.All adjustaments are remote controlled from a PC with a dedicated software.Only the slit aperture isn't for i changed the initial remote controlled sophisticated slit with a simple (but effective) Edmund 5 micron air slit.About the polarimeter, I agree with you In my work of 2017 my results are quite in the median of those professional, and this is enough for me.
- Has thanked: 17521 times
- Been thanked: 8763 times
Well done!! fascinating
