July 16 2022 CaK close-ups
- Has thanked: 1262 times
- Been thanked: 1057 times
Hi all,
I was a bit lucky to see M-class flare on Saturday in the morning, but only through high clouds. Than I switched to Ca waylaying gaps in clouds.
I'm quite satisfied with my CaK dedicated 120mm achro with a distance between lenses 2mm, tinkering worth it. With a good seeing less than ~1" all 120mm of aperture works like 200mm in Ha.
The issue I try to solve is blurred and faded spicule layer and proms in Ca, maybe it's also due to low DR of 174 chip at 393nm.
Here are AR's: 3053, 3055, 3056, 3057, 3058, 3059.
regards
Leo
regards
Leo
- 3059
- Sun_20220716 122949_cOAIdPs AR3059.jpg (530.18 KiB) Viewed 650 times
- 3058
- Sun_20220716 121412_AIwOPs AR3058.jpg (848.03 KiB) Viewed 650 times
- 3057
- Sun_20220716 115916_AIPs AR3057.jpg (640.4 KiB) Viewed 650 times
- 3056
- Sun_20220716 122834_AIwOPs AR3056.jpg (699.39 KiB) Viewed 650 times
- 3055
- Sun_20220716 121630_AIwOPs3 AR3055.jpg (848.3 KiB) Viewed 650 times
- 3053
- Sun_20220716 121518_ AIwOPs AR3053.jpg (519.57 KiB) Viewed 650 times
- Ha&Ca
- Sun_20220716 0635 115916_AIPs AR3057 M11flare.jpg (809.68 KiB) Viewed 650 times
- Has thanked: 1640 times
- Been thanked: 878 times
Re: July 16 2022 CaK close-ups
These are very good calcium images. Looks like you have a great system
- Has thanked: 9145 times
- Been thanked: 6026 times
- Been thanked: 10248 times
Love these shots Leo!
You've done some stretching of the shadows to bring them out, I don't think the issue is the dynamic range of the camera, although it may be worth trying it in 16 bit (12 bit really) mode and seeing if you get any difference - it's more the signal to noise ratio of the filter system. If you're looking to bring out the spicule layer and proms like this, to increase your chances you firstly need to be double stacking the filter and secondly both elements of the filter will need to be clocked and tilted for optimal performance.
I find the proms and spicule layer only reveal themselves fully when sky transparency is at its highest, any haze, contrails etc definitely impact. I do wonder in summer season how much NLC make an impact too.
Keep them coming!
Keep them coming!
- Been thanked: 4787 times
Thanks for your comments, Alan, Franco and Mauruts!
Yes, Mark, in any case the main factor is seeing, which, as I remember, deteriorates about 1.2 times faster with a decrease in wavelength compared to the aperture. This time the seeing was worse in average than the previous one here viewtopic.php?t=37077 and stacking result showing a tiny granulation structure not so correct. I've seen only once fantastic spiculae forest in CaK on the screen in 300% scale with totally frozen air for a second, so I know I haven't reached the limit yet.
Of course, DS system is the next step.
regards
Leo
regards
Leo
- Been thanked: 8793 times
For CaK spicules, IMHO, it is transparency, not seeing, I can get CaK spicules quite easily at 60mm aperture when the transparency is excellent. If the transparency is not there, then the image has less contrast and a lower signal to noise ratio making the low contrast spicules much harder to see, regardless of increase in aperture.LeoD wrote: ↑Wed Jul 20, 2022 7:17 am Yes, Mark, in any case the main factor is seeing, which, as I remember, deteriorates about 1.2 times faster with a decrease in wavelength compared to the aperture. This time the seeing was worse in average than the previous one here viewtopic.php?t=37077 and stacking result showing a tiny granulation structure not so correct. I've seen only once fantastic spiculae forest in CaK on the screen in 300% scale with totally frozen air for a second, so I know I haven't reached the limit yet.
regards
Leo
The other factor is spherical aberration at 393nm, but you have that sorted with the spaced objective lens.
Ok, transparency. This is a part of FD image in prime focus with visible proms and spicules, from the same session. Sure even with full resolution of 183 camera there are no small details, but more light and less noise, 0 gain, 2.2ms. I'll try to find the best match for such a case next time.marktownley wrote: ↑Wed Jul 20, 2022 7:52 pm
Thank you.
- SE part
- Sun 20220713 SE FD_AIO.jpg (527.97 KiB) Viewed 549 times
I think you're doing a great job with these CaK images Leo, it might help others to describe how you pull out the proms and spicules in post processing.
- jp-brahic
- Has thanked: 45 times
- Been thanked: 131 times
very nice Cak images !!!
jp
jp
TN 450mm F/D 4 Zerodur
Thank you, JP!
I'll be happy to share it in the chat . I got to get my wits about it, make another imaging session and once again check out the best way of limb processing.marktownley wrote: ↑Fri Jul 22, 2022 5:19 am I think you're doing a great job with these CaK images Leo, it might help others to describe how you pull out the proms and spicules in post processing.
- Been thanked: 2713 times
This is excellent Leo !
Spicules and prominces are rather faint in Ca K (compared to Ha). No much can be done about it, except better seeing conditions and a Ca K filter with smaller FWHM.
- Has thanked: 6181 times
- Been thanked: 7142 times
Excellent results, Leo!
You might have stated this earlier, but which CaK filter are you using again?
Arne
Arne
- Has thanked: 8418 times
- Been thanked: 8165 times
Amazing images Leo. You've got a great Lunt CaK filter there. Very nicely done.
