DS or Quark..
Alto
Has thanked: 962 times
Been thanked: 334 times
DS or Quark..
Post by Alto »
Hi all,
May I pick your brains and thoughts.
What would be a better option for me.
To DS my ls60tha at ~£2.6k - at least remote operating is possible; or
Quark Chromo, in spite of its need to warm up and limited option for remote, at ~£1.5k + extra filter.
The latter might work on my Lunt, or will work on my 4inch refractor...
Any views? Imaging opportunities seem few in number these days, not had
any real chances for some weeks due to cloud.
Geoff
Call me Geoff.
vkx86
Has thanked: 41 times
Been thanked: 56 times
Re: DS or Quark..
Post by vkx86 »
Alto wrote: Fri Jul 22, 2022 11:21 am ...or will work on my 4inch refractor...
As visual-only observer, with my setup - ED 80 f/7.5, I always prefer 80 mm aperture vs 54 mm stopped because of details.
If you have a good seeing for Solar - 4" aperture will show a lot of detail on Sole, so I would go Quark.
TareqPhoto
Has thanked: 607 times
Been thanked: 402 times
Re: DS or Quark..
Post by TareqPhoto »
I went with the Quark [combo] version because i have a lot of scopes, so i thought that will be a better option than just a dedicated solar scope at fix certain aperture, i want to have flexibility more, so i hope i can use this Quark and see if i did right choice.
Has thanked: 20756 times
Been thanked: 10442 times
Re: DS or Quark..
Quark is going to give you hi-res, the DS on the Lunt is going to give you higher contrast full disks.
FLO have a reduced Quark combo for sale at the moment.
TareqPhoto
Re: DS or Quark..
marktownley wrote: Sat Jul 23, 2022 2:34 pm Quark is going to give you hi-res, the DS on the Lunt is going to give you higher contrast full disks.
What is the difference between the hi-res and high contrast? And which one you prefer if so?
cybermayberry
Has thanked: 1838 times
Been thanked: 1283 times
Re: DS or Quark..
Post by cybermayberry »
The quark also has a built in barlow making full disc very impractical except for mosaics.
The Quark will work on your 4 inch refractor but you will need a ERF in front as well for such a large aperture. (additional expense). The Quark and the ERF may end up about the same price as getting the DS as well.
You may want to just look at some examples taken with both options and base your decision of those results.
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
Re: DS or Quark..
Hey Geoff.
You could do the best of both worlds option - get a LS50C etalon (you will need a m80 to m90 adapter) to double stack the LS60, and also get a Quark - you might have a UV/IR cut or Ha filter you can already use as a sub aperture ERF.
This would cost the same as a 60mm double stack unit for the Lunt.
Alto
Re: DS or Quark..
Post by Alto »
Many thanks for your advice all....Much to consider whilst the clouds continue to roll on across!
Call me Geoff.
Alto
Re: DS or Quark..
Post by Alto »
Looks like a Quark option is the quicker way, as Lunt DS filters seem rarer than hen's teeth!
Call me Geoff.
