Hi again,
I want to know which one do you prefer to use with the Quark, a red filter or Ha that is about 25-40nm band?
Should i place this at the nose of the Quark and use UV/IR Cut in the beginning like end of the scope to protect anything behind it all way to the sensor? If so why not place Ha/Red first then UV/IR cut next to the Quark/camera then?
Ha or Red filter with the Quark?
- Has thanked: 580 times
- Been thanked: 389 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Ha or Red filter with the Quark?
All filters that are used as an ERF need to be the dielectric type which reflect energy, rather than absorptive or dyed glass.
So, get a Ha filter.
You should place this before the quark, ideally on the nosepiece of the 2" diagonal.
Ok, i will go with the Ha then, thank you very muchmarktownley wrote: ↑Sat Jul 23, 2022 2:37 pm All filters that are used as an ERF need to be the dielectric type which reflect energy, rather than absorptive or dyed glass.
Bringing back this thread as i want to say that i ordered P1 Chromo filter to use with my Quark, few months ago i bought a filter of Ha 40nm cheap one, but to my bad luck it has larger mount thread than 1.25", not sure maybe 33mm or 35mm not sure so slightly larger than 1.25" size, i really don't know how to find an adapter or ring to mount this if i want to use it, but now with the P1 filter which is almost as red i won't care about that filter, i will keep it just in case.
So now i stop down the scope, i use UV/IR cut filter and this additional P1 chromosphere filter, do i need anything else? Let's say with scopes of 80mm, 60mm and 90mm i am fine with this setup? Because my Quark is a combo version so i need to use a telecentric Barlow, i have 5x Powermate, should i place that after the Quark means between the quark and camera? And where should i put that chromo filter, on the nose of Quark or Powermate?
