Some images from last week (finally had time to start processing them)
All captured on the Skywatcher ED120
CaK was at 84mm with 2x barlow using ASI290MM and Lunt B1200 CaK module
WL was at 105mm with 3x barlow using ASI290MM, Badder 2" Herschel wedge and Continuum filter
Ha 120mm with Quark and ASI174MM using Baader 35nm Ha as an internal ERF
Conditions less than ideal, it was clear and sunny all day but pretty windy, seeing was jumping between 1" and 2+ " all morning.
Triptych
CaK
WL
AR13056 on 18th July 2022
- Rob63
- Has thanked: 599 times
- Been thanked: 620 times
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
Re: AR13056 on 18th July 2022
Wow!! these are absolutely superb I really must get out solar imaging again
- Has thanked: 977 times
- Been thanked: 344 times
Brilliant.
It's illuminating to see all the various elements in each of the 3 bands, especially when they coincide across all the layers. Wow.
Call me Geoff.
- Has thanked: 9319 times
- Been thanked: 6157 times
- Rob63
Indeed you must Alexandra (especially with the Solarscope 100 ), your work was one of the main inspirations to get me into Solar Astronomy in the first place.
Rob.
- Has thanked: 17853 times
- Been thanked: 16996 times
Very nice work!!
- nicspenceryork
- Has thanked: 6034 times
- Been thanked: 1310 times
- Been thanked: 10489 times
These are excellent Rob, thanks for sharing!
- Rob63
Thanks Nic,
I was really just testing various aperture masks and barlow combinations but noticed I had three decent views of the same AR.
I like the results and will be trying this again when I get some decent seeing.
Rob.
- Rob63
Thanks Mark
