Dear friends,
I've finally managed to process the continuum image from last Tuesday (July 19th).
The images was obtained using a Celestron 9.25" SC XLT with a full-size photographic solar filter. I actually made a sequence of recordings in an attempt to make a continuum timelapse, but the seeing was just not stable/good enough for this and I just ended up processing a few selected still images.
I tried imaging at both the native focallength of 2350mm and with a Coronado CeMax 2x barlow which should give 1.83x and ~4300mm at the attached position. The first resulting in a slight undersampling with the Player One Mars-M and the latter a slight oversampling. I have to find a good solution to bring the fl somewhere in the range of 2500-3800mm.
Anyhow, below are the results under mediocre seeing.
Click on images to view them in full size on AstroBin.
Continuum using a Celestron 9.25" SC XLT, Kendrick Photographic Solar Filter with Solar Finder ND3.8, Baader CCD Green filter (500-575nm) and Player One Mars-M mounted on a Sky-Watcher AZ-EQ6-PRO
Continuum using a Celestron 9.25" SC XLT, Kendrick Photographic Solar Filter with Solar Finder ND3.8, Coronado Cemax 2x Barlow 1.25", Baader CCD Green filter (500-575nm) and Player One Mars-M mounted on a Sky-Watcher AZ-EQ6-PRO.
Arne
Sun in Continuum 19th of July 2022
- Has thanked: 6296 times
- Been thanked: 7302 times
- rigel123
- Has thanked: 8562 times
- Been thanked: 8797 times
Re: Sun in Continuum 19th of July 2022
Pretty good mediocre seeing to see the cells so well, nice job!
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Great set of images, Arne. Great resolution of the granular pattern.
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Has thanked: 17970 times
- Been thanked: 8904 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Promising results, thanks Arne.
- Has thanked: 8543 times
- Been thanked: 8278 times
Very nice, Arne. Lots of lovely details in those penumbra.
Thank you very much Warren, Jordan, Alexandra, Maurits, Mark and Stu!
The poor seeing made it really challenging to focus, but taking a lot of recordings a few of them came out ok. Hoping for better seeing next time around.
Arne
Arne
This event was great. I am convinced that this is one of the most important events when it comes to the activity of the sun in the last style.
__________________________________
https://samozatrudniony.pl/
