Page 1 of 1
Solar N200/F4 (176/F4.5) + Quark Chromo + D-ERF 180mm + ASI174M
Posted: Sun Jul 31, 2022 8:16 am
by pupak
The very first light on the test set. Uncollimated Newton without adjustments and apertures.
I wanted to test whether such a combination would bring a usable result. Seeing was bad, Quark set by guesswork, but the first photo suggests it should work. Be forgiving.
Re: Solar N200/F4 (176/F4.5) + Quark Chromo + D-ERF 180mm + ASI174M
Posted: Sun Jul 31, 2022 9:27 am
by marktownley
Good luck!
I've not seen this when tried before work with any prolonged success, maybe you will be the first!
Posted: Sun Jul 31, 2022 10:30 am
by pupak
I like to walk untrodden paths all my life.
Posted: Tue Aug 02, 2022 5:10 pm
by MapleRidge
Excellent results for the setup...well done
I was able to get my quark combo to work on a 150mm newtonian, but it wasn't well suited to put Newtonian in the observatory so I didn't pursure the idea. Good luck with yours!
Posted: Wed Aug 03, 2022 1:40 pm
by pupak
New configuration. N200/F6, (176/F6.8), D-ERF1800mm, LS80DSII + Quark + IMX432. Very good for prominence in right colors.
Posted: Sat Aug 06, 2022 9:39 am
by banjo
nice picture ,
you can give a detailed photo of the last assembly
Posted: Sat Aug 06, 2022 9:56 am
by pupak
The assembly is disassembled and will be reconstructed as a lattice structure.
As soon as I finish it, I will post the photos here.
Posted: Tue Aug 09, 2022 2:58 pm
by allhoest
For some unknown reason, the netwon tubes are more prone to instrumental turbulence than closed tubes (HaT, refractors).
I would suggest to rebuild your setup as an open system, like a truss, if you have the chance to do so.
Probably the DERF let 100nm passing through (I don't know the exact spectral curve), so you can figure how much heat will pass through.
Your mirror coating is probably of standard type -> It will absorb ~8% of the incident heat.
Then reflect toward the secondary, which will also absorb ~8%.
CS
Alex
Posted: Tue Aug 09, 2022 5:12 pm
by Carbon60
The last image is a beauty. Nice one.
Posted: Tue Aug 09, 2022 5:38 pm
by pupak
I am building a new telescope as an open tube. The primary mirror 200mm/F6 has a coating of 98% reflectivity, the secondary 96%. In addition to the main D-ERF 180mm, the set also includes a 2" ERF LUNT. The central shading will be reduced by using a 44mm diameter mirror. The Lunt LS80 will be used as a double etalon in combination with Quark.
Sorry for my poor english.
Posted: Wed Aug 10, 2022 1:26 pm
by OlegLviv
Am wainting your new tube because wants too big aperture 150mm hand made! Your English normal friend how my=))) I want buy ERF but 800$ and tax more for me.....
Posted: Wed Aug 10, 2022 2:14 pm
by pupak
It's quite an expensive project. 180mm D-ERF 1700,- Euro, mirrors 600,- Euro, duralumin 450,- Euro, two etalons 4,000,- Euro and my work is priceless.
Posted: Wed Aug 10, 2022 3:46 pm
by pupak
This is the cause of the delay of the solar N200/F6 project. Today I finished a new mount with harmonic gears for my friend and tomorrow the Newton project starts.
